Forums >> Revit Structure >> Technical Support >> TOPOGRAPHY SPLIT PROBLEM
Fri, Sep 19, 2008 at 3:21:23 PM | TOPOGRAPHY SPLIT PROBLEM
arch04
I am new to the forum, but do have some experience with revit.  I have completed a topography with a residential house.  I have split the topography so there is a hole in the topography for the basement and walk out form the basement with retaining walls. My question is  CAN I EDIT THE HOLE I HAVE ALREADY CREATED OR do i have to draw the topography again??
REVIT 9.0
Fri, Sep 19, 2008 at 4:57:59 PM | TOPOGRAPHY SPLIT PROBLEM
4 Stars: 205 Votes
Well, that's a dilemma, "I have split the topography so there is a hole in the topography for the basement", did you DELETE that portion of surface? or did you create a "PAD" to that basement???? can you put some screenshots to that "TOPOGRAPHY SPLIT PROBLEM"???
Mon, Sep 22, 2008 at 10:34:41 AM | TOPOGRAPHY SPLIT PROBLEM
arch04
Yes the portion of surface was deleted, the detailer believes he whe to site, then split surface, then outlined the area then finish sketch.
REVIT 9.0
Mon, Sep 22, 2008 at 11:22:26 AM | TOPOGRAPHY SPLIT PROBLEM
4 Stars: 205 Votes
Hi, well how do edit the HOLE? it's a hole, it's mean there are NOTHING, so you can't edit what don't exist, if you create with that portion of surface a PAD then you can edit and change the elevation up or down like do you want/need....
Mon, Sep 22, 2008 at 2:51:42 PM | TOPOGRAPHY SPLIT PROBLEM
arch04
GOOD POINT, but you can hide a hole...lol Got It
REVIT 9.0
Topography split tool issue
Thu, Apr 18, 2019 at 5:55:11 AM
Scheduling cut and fill when using split regions
Sun, Sep 21, 2008 at 8:56:58 AM
splitting topography
Wed, Jan 19, 2005 at 8:36:37 PM
TOPOGRAPHY PROBLEM
Wed, Jan 27, 2010 at 10:47:10 AM
Topography Issues
Fri, May 18, 2007 at 9:38:48 AM
Page generation time: 1.7785
