Forums >> Revit Structure >> Technical Support >> Filled Regions (Hatch patterns)
Fri, Sep 19, 2008 at 7:54:56 AM | Filled Regions (Hatch patterns)
mreed
Can someone tell me how to change the line weight or darkness of hatch patterns?  When I plot the sheets the hatch is way to light.
Thanks.
Mon, Sep 22, 2008 at 2:55:35 AM | Filled Regions (Hatch patterns)
mgr2820
2 Stars: 2 Votes
Model hatches are controlled by the #1 lineweight of the scale you are in. Drafting filled regions have independant lineweight control.
Unfortunately, Revit ships with many object styles also set to the #1 lineweight. In our office, we change the object syle settings, reserving #1 for material patterns only, 2 thu 7 are for model categories, 8 thru 15 are for linestyles, and 16 is a leader line weight set to match the leader line in the annotation settings.
Fri, Mar 28, 2014 at 1:50:15 PM | Filled Regions (Hatch patterns)
swdebenport
5 Stars: 3 Votes
mgr2820 how can you change the weight of the drafting patterns
Hiding Hatch Patterns [ 1 2 ]
Sat, Aug 29, 2009 at 8:12:25 AM
15
transparant hatch patterns
Wed, Feb 27, 2008 at 1:05:34 AM
Filled Regions on an elevation
Wed, May 25, 2005 at 1:35:38 PM
Filled regions and Hatching
Thu, Aug 24, 2006 at 2:20:06 AM
Scaling Hatch patterns
Tue, Apr 18, 2006 at 11:48:59 PM
Page generation time: 0.1504
