Forums >> Revit Systems >> Technical Support >> imported grid offset from crop region
Fri, Sep 19, 2008 at 4:47:10 AM | imported grid offset from crop region
Archiman28
hey
 im working on a large project where the grid has been separated out into its own file. The problem is that when i cut sections in my building file, the imported grids have quite a large offset from the crop region, which means that they take up a lot of space (vertically) on the sheets.
if the grid was in the building file i could just drag them down and up to make a more compact layout, but since i cant do this, i was wondering if there was another way to control the OFFSET of the grid bubbles and tails from the crop region?
Crop region not affecting grid lines
Tue, Oct 19, 2010 at 4:00:29 PM
LINKED COLUMN GRID BUBBLE OFFSET
Thu, Mar 25, 2010 at 2:05:39 PM
Crop Regions can't crop imported images
Mon, May 5, 2008 at 2:25:13 AM
Crop region not working
Wed, Apr 13, 2005 at 2:04:51 AM
Grid lines from link outside of crop area [ 1 2 ]
Mon, Jun 27, 2011 at 1:49:59 PM
19
Page generation time: 1.4388
