Forums >> Revit Building >> Technical Support >> wall cut lines not displaying
Thu, Sep 18, 2008 at 6:08:02 PM | wall cut lines not displaying
Warchitect
4 Stars: 5 Votes
revit arch 2009
 check this picture.
the small guest house to the right is the main floor view active, but walls get cut thin line. you can see over to the left on the main building cmu wall is cut nicely....can anyone tell me why this might happen. the walls are the 6" basic stucco...its being cut by the cut plane. its the main view and the walls are for sure associated this level. grafix show the proper options... please help.
Fri, Sep 19, 2008 at 3:31:05 AM | wall cut lines not displaying
4 Stars: 205 Votes
Are you sure about the "Cut Plane" in the View Range????
Displaying a wall above the cut line
Wed, May 21, 2008 at 12:44:45 PM
Revit 2009: Invisible lines displaying as dashed lines
Sat, Nov 14, 2009 at 11:57:17 AM
11
Very basic question about displaying lines
Mon, Apr 28, 2008 at 11:35:53 AM
I can't see wall with section lines eventhough cut plan passes through the wall!
Mon, Sep 15, 2014 at 9:42:29 PM
Section cut lines
Tue, Feb 2, 2010 at 9:44:41 AM
Page generation time: 1.8571
