Forums >> Revit Building >> Technical Support >> purge selected
Tue, Sep 16, 2008 at 7:12:09 AM | purge selected
durgeshbrijwasi
Is there any way by which i can purge only the selected family types..e.g. can i purge on the wall types or the door types..
coz if i purge unused then the system stops responding as the file has become too heavy...
Tue, Sep 16, 2008 at 7:26:47 AM | purge selected
tim123
4 Stars: 19 Votes
If you go to the purge unused dialogue box and 'check none' you can then highlight only the items you want purged.
Tue, Sep 16, 2008 at 7:36:44 AM | purge selected
You can go down through your family tree and individually delete the families or just types from a family.  If the family or type is being used, REVIT will warn you.
Wed, Sep 17, 2008 at 12:12:23 AM | purge selected
durgeshbrijwasi
but if i click purge unused from file menu, the system stops responding ,is there any other way by which i can perform the same thing and get the selection box..??
Wed, Sep 17, 2008 at 9:03:18 AM | purge selected
Are you sure it quit or did you not wait long enough for it to filter the database.  Large projects with many families may take awhile.
Wed, Sep 17, 2008 at 10:40:42 PM | purge selected
durgeshbrijwasi
i had wait for around 2 to 2 1/2 hrs but it didnt come.
Text style that I can't get purge
Wed, Sep 5, 2012 at 8:40:41 AM
Where are Regions in the Purge List
Tue, Feb 14, 2017 at 10:33:21 AM
Purge Command - possible to purge family types accidentally?
Tue, Aug 20, 2013 at 12:01:08 PM
Delete or Purge out Title Blocks?
Wed, Nov 26, 2008 at 5:06:00 PM
how I purge or delete materials not used?? [ 1 2 ]
Wed, Sep 9, 2020 at 8:27:42 PM
15
Page generation time: 1.8526
