24 Users Online (22 Members):
Forums >> Revit Structure >> Technical Support >> TOS in framing tags?
21 Posts No Rating |
Is it possible to place the live level of a steel beam into a framing tag?The reason is purely from a drafting point of view, we need to see some top of steel levels on our plans for certain steel members. At the moment, we have a framing tag which obviously picks up the steel size and then below it we just have a line of text which we type in the TOS levelIt would be better if we could have that TOS level as a live level, so that when we change the levels of the job (which is about to happen), we don't have to go through and retype all of the levels of each individual steel, which also of course leaves us open to human errorAttached is the tag we are currently using.Is this possible please?Thank you
What version of RS are you using? In v2009 you can use beam annotation command to tag all beams with a t.o.s. elev and then when you move it the elev will change respectively. Hope that helps.
Is there a way to add in a symbol with the beam elevation tag? I am trying to transfer firm standards from CAD into Revit and I am trying to find a good way to do joist-bearing elevation (TOS) tags. So far...not so much luck.
Visibility of Door Thresholds |
Wed, Jul 1, 2009 at 9:44:08 AM
Custom Structrual Framing Tags |
Thu, Sep 11, 2008 at 3:49:22 PM
Wood Framing Walls Extension; Locating and External framing |
Fri, Jul 31, 2015 at 8:03:14 PM
wood framing extension |
Mon, May 7, 2012 at 3:23:48 PM
Levels- can they have the same name? |
Wed, Jul 28, 2010 at 10:51:43 AM
