Forums >> Revit Building >> Technical Support >> Valueless Dimensioning
Wed, Apr 27, 2005 at 5:38:47 PM | Valueless Dimensioning
kkim
Hi. I need to dimension a run of stairs by labeling with the number of treads (i.e. (11) T @ 11" = 10' 1"Winking instead of the numeric value of the distance measured. Revit won't seem to let me delete (override) the given value of the dimension in order to enter an alternative text entry. I know I can add text to the dimension line by adding a prefix and/or suffix to the automatically generated value, but can I remove the 'value' of the distance entirely and enter other text?
Wed, Apr 27, 2005 at 6:52:43 PM | RE: Valueless Dimensioning
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not possible and don't believe and prefer it never was... This would open the door for laziness and possible errors. Why couldn't you dimension the whole flight from first tread to last to get the overall distance 10' 1". Then add a prefix to this (11) T @ 11" =... This should give you what you require?
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:55 PM
Better Leaders For Dimensioning
Wed, Nov 24, 2010 at 7:52:57 AM
Dimensioning and then hiding objects?
Wed, Nov 7, 2012 at 2:34:01 PM
Isometric Views and Dimensioning
Mon, Feb 22, 2010 at 3:20:22 PM
Dimensioning railings
Fri, Jul 24, 2009 at 3:04:00 PM
Page generation time: 0.9008
