Forums >> Revit Building >> Technical Support >> How do you trim to a radius rather than a 90 degree corner?
Mon, Sep 15, 2008 at 3:02:28 PM | How do you trim to a radius rather than a 90 degree corner?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Would like to trim walls and lines to a preset radius.  Seems like I heard there was a way but no luck searching Revit Help.
Revit 2009 latest build
Mon, Sep 15, 2008 at 3:05:15 PM | How do you trim to a radius rather than a 90 degree corner?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
don't use the trim command, use the "fillet arc" command. It's on the options bar once in the wall command.
Mon, Sep 15, 2008 at 3:09:21 PM | How do you trim to a radius rather than a 90 degree corner?
4 Stars: 205 Votes
Hi see the video: http://screencast.com/t/bIMFMBDEYB
Mon, Sep 15, 2008 at 3:13:27 PM | How do you trim to a radius rather than a 90 degree corner?
alabaster2513
3.5 Stars: 25 Votes
typhoon was that you on JING? You use it alot don't you? Uhh and is it free for real?
Mon, Sep 15, 2008 at 3:15:44 PM | How do you trim to a radius rather than a 90 degree corner?
4 Stars: 205 Votes
Yes Alabaster, it's me and IT'S FREE FOR REAL man.... i think an image paints more than 1000 words... don't you think so?
Mon, Sep 15, 2008 at 3:17:36 PM | How do you trim to a radius rather than a 90 degree corner?
alabaster2513
3.5 Stars: 25 Votes
yeah i like it!
Is there a way I can embed the tutorials I create into my internal office wiki so it plays the video, not just displays a link to JING?
Mon, Sep 15, 2008 at 3:23:53 PM | How do you trim to a radius rather than a 90 degree corner?
4 Stars: 205 Votes
Well, if you go to the 2 buttom (in middle) of JING you have "History" and if you pick in one image or video you can see you can "Share" or "Embed" but i don't know if you could "embed" the video files of your tutorials (made in other programs) to JING, i think you can go to Jing site and try to check if there are some awnsers about that.... you also can create "images" - Screen shots, did you see that???
Mon, Sep 15, 2008 at 4:11:03 PM | How do you trim to a radius rather than a 90 degree corner?
coreed
coreed Avatar
4 Stars: 16 Votes
you can save your videos directly to your hard drive if you want. you do not have to upload them to the jing site.
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Sep 15, 2008 at 4:13:55 PM | How do you trim to a radius rather than a 90 degree corner?
4 Stars: 205 Votes
Yeah, Coreed it's right, like you can save uour images to the disk you also can save the video...
Mon, Sep 15, 2008 at 4:22:09 PM | What about radius trimming lines?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Why isn't there a radius trim option available for everything?  Hasn't autocad had this for years in ADT?  Why not Revit?
Mon, Sep 15, 2008 at 4:53:37 PM | How do you trim to a radius rather than a 90 degree corner?
#11
alabaster2513
3.5 Stars: 25 Votes
Hogmodo,
Autocad are Revit are two totally different programs.
Why can't my wife cook? My mom can!
I did find with the video "embed" link, I can just paste it into my <html></html> code on my wiki. Now i just need to figure out how to resize it.
Tue, Sep 16, 2008 at 8:54:38 AM | One of the main differences is an apathetic attitude by Revit software folks....
#12
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
...............towards the every day Revit user.  It is obvious that trimming to a radius is possible in Revit. It is available under the wall command.  Adding that trim option to the trim selection list for lines is just too much trouble to worry about.  This is another situation that reinforces the impression that Autodesk is more concerned with making Revit more Bimmy and is not really concerned about making it work better for the normal user.  We early Revit users complained long and hard that it was stupid for Revit to not allowing "selection box to the right picks enclosed and selection box to the left picks everything crossed" like Autcad had always done.  Finally, it got added.  Revit was never not capable of it, they just hadn't bothered to put it in.
Help! Forgot how to trim with a radius corner.
Mon, Jan 8, 2007 at 8:25:35 AM
Corner Trim with Vertical Sweeps
Thu, Aug 31, 2017 at 2:32:51 PM
trimming trim corner.
Wed, Feb 1, 2012 at 12:09:41 PM
trim/extend to corner
Thu, Nov 4, 2010 at 6:10:31 AM
corner trim
Fri, Apr 2, 2004 at 2:17:39 PM
Page generation time: 0.1005
