Forums >> Revit Structure >> Technical Support >> Wall Footings
Mon, Sep 15, 2008 at 1:59:32 PM | Wall Footings
mreed
Is there a way to make the wall footings (thickened slabs) to pass thru openings in plan view?  I am putting a thickened slab under an interior wood stud bearing wall, but on the plan it stops and starts back at all doors.
Thanks
Mon, Sep 15, 2008 at 2:17:58 PM | Wall Footings
4 Stars: 205 Votes
Hi, can you put some screen shots fo figure it out???
Mon, Sep 15, 2008 at 2:44:55 PM | Wall Footings
mreed
See attached screen shot.
Mon, Sep 15, 2008 at 3:16:38 PM | Wall Footings
4 Stars: 205 Votes
Hi, see the video: http://screencast.com/t/vtJgwrPm
Mon, Sep 15, 2008 at 3:33:32 PM | Wall Footings
mreed
I figured out another way to do it.  If you change your "Sill Height" of the door to anything > zero, then your footing will show up.
Mon, Sep 15, 2008 at 3:38:57 PM | Wall Footings
4 Stars: 205 Votes
Well, like i tell you in the video, i don't know how is your wall, but, what you say is your doors are attached to that "foundation Wall" isn't?
Mon, Sep 15, 2008 at 3:54:35 PM | Wall Footings
mreed
I don't think the doors are attached to the "foundation wall".  I think that in Revit, if you put in a length for your sill height then it puts a short piece of wall under the door equal to the height of your sill.  The wall footing then connects to this short piece of wall.
Mon, Sep 15, 2008 at 3:57:39 PM | Wall Footings
4 Stars: 205 Votes
Can you put animage in 3D view to see those walls with the door?
Mon, Sep 15, 2008 at 4:21:41 PM | Wall Footings
mreed
Attached is a 3D image of the door.  You can see the line on the floor which is the edge of footing.  I put in a 1/2" sill height.  It doesn't appear any different than a typical door.
isolated footings not showing up
Wed, Jul 18, 2012 at 1:17:11 PM
Revit creates two footings at compound wall
Mon, Apr 27, 2015 at 9:22:17 AM
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Footings
Mon, Dec 17, 2012 at 1:31:16 PM
Footings w/ eccentricity assigned
Thu, Sep 3, 2009 at 9:25:14 AM
Page generation time: 1.2386
