Forums >> Revit Building >> Technical Support >> door opening cutting parallel wall
Mon, Sep 15, 2008 at 10:24:07 AM | door opening cutting parallel wall
bridgett
I have a door which appears to be cutting a hole in the parallel wall.  Coincidentally, it is cutting the paralell wall up to 5feet back from the door.  I looked in the family, and do not see how to set any depth on the cut opening.  Help!
I have even tried different door families, to no avail.
I am using Revit 2009.
Bridgett
Mon, Sep 15, 2008 at 2:45:48 PM | door opening cutting parallel wall
BRIANHADLEY
Try and use unjoin geometry on the parallel wall.  If the walls have been joined with the join geometry command the door will cut both walls.
Mon, Sep 15, 2008 at 2:54:10 PM | door opening cutting parallel wall
bridgett
That did not work, but I rehosted it to the same wall, and problem fixed.  Weird.
parallel door opening in circular wall
Wed, Jan 9, 2008 at 11:29:19 AM
Parallel walls join geometry do not cut opening
Fri, Jan 31, 2020 at 1:32:48 PM
Door not cutting joined wall
Wed, Feb 14, 2018 at 12:54:54 PM
Wall opening (door)
Tue, Mar 31, 2015 at 10:58:12 AM
Demo door, make cased opening, no fill in wall
Fri, Mar 23, 2012 at 12:34:24 PM
Page generation time: 1.7343
