Forums >> Revit Building >> Tips & Tricks >> existing walls
Tue, Jan 27, 2004 at 3:01:14 PM | existing walls
sfaust
I am doing a small renovation and I would like the existing walls to show without hatching/patterning. Does anyone know a good way to make that happen? I can't seem to find it. Thanks, Steve
Tue, Jan 27, 2004 at 4:03:02 PM | RE: existing walls
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
go to settings/materials and find the material called phase-exist. Edit the cut properties to your desires. For instance, we show our existing walls as solid black. We give the phase-exist material that cut pattern. You could give it a solid white pattern
Hiroshi Jacobs
Wed, Jan 28, 2004 at 10:33:50 AM | RE: existing walls
sfaust
thanks, that worked well for section, but it doesn't seem to be working for the plans. Is there a way to make it work for plan as well? steve
Wed, Jan 28, 2004 at 10:45:31 AM | RE: existing walls
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
that should work for plans just fine too...
Hiroshi Jacobs
Tue, Apr 8, 2008 at 1:49:02 PM | existing walls
jjlangh
jjlangh Avatar
3 Stars: 2 Votes
I sort of have the same issue: i am working on an addition and have existing walls and floor that i want to show grayed-out in plan and section, but the client also would like to see a 3D image of the existing building with the addition. In the 3D image i don't want to have the existing show up as gray and the addition with the correct material. Is there a way to surface apply a material in the element properties structure tab so that it just shows up in the 3D?
Tue, Apr 8, 2008 at 2:31:02 PM | existing walls
jjlangh
jjlangh Avatar
3 Stars: 2 Votes
Nevermind - i just got it figured out.
Walls set as existing not showing up in existing phase settings.
Sat, Aug 4, 2012 at 11:21:58 AM
hatch existing walls black (phasing)
Fri, Jun 2, 2006 at 7:35:19 AM
Rendering existing storefront walls
Thu, Oct 20, 2005 at 4:43:44 PM
existing walls
Wed, Jul 3, 2013 at 10:19:13 PM
Rendering- existing walls and Windows
Mon, Sep 26, 2011 at 3:41:09 PM
Page generation time: 3.2838
