Forums >> Revit Systems >> Tips & Tricks >> Heat loss calculation formula
Fri, Sep 12, 2008 at 4:23:42 PM | Heat loss calculation formula
dcbrewer
The company I work for wants me to get Revit to do a heat loss calculation based on how they do it by hand.  My first hangup is trying to get Revit to find the linear feet of exterior wall per room.  Is that even possible?  The rest of the calculation is pretty standard.  Heat loss/gain for Wall, window, door, infiltration, floor, roof, lights, people and equipment for each room.
 Any suggestions?
 Thanks in advance.
Mon, Sep 15, 2008 at 5:47:56 AM | Heat loss calculation formula
Wazza
There is a program called daysim that one can download off the web for free. will sort out all your heat loading calcs.  works well with revit
Wed, Sep 24, 2008 at 3:16:36 PM | Heat loss calculation formula
KKERRIDGE
KKERRIDGE Avatar
2.5 Stars: 3 Votes
Do you use load calc software after you have calculated the heat loss for the walls by hand?
If so have you tried export to gbxml? I use Trace load calc software this way, It exports the wall data to the program then I can set my wall, floor, roof & window U-values to what I need. This way all window and wall data is exact and wall direction is already set.
Wed, Apr 29, 2009 at 10:09:09 AM | Heat loss calculation formula
SAPLAiLCC
Hi
dcbrewer
You solve problems from heat loss calculation, Heat loss/gain for Wall, window, door, infiltration, floor, roof, lights, people and equipment for each room. I have this formulate rand and pratice exeplefly. Confirm me in your interest.
I expect return Ok !
Grateful !
Heat Loss Through ground?
Sat, Sep 1, 2012 at 2:09:26 AM
Revit interior walls transmission area calculation
Tue, Oct 28, 2014 at 1:44:23 PM
duct static pressure loss
Mon, Aug 15, 2011 at 2:18:11 PM
ASHRAE TBL files and pressure loss calculation in Revit MEP 2012
Sun, Sep 4, 2011 at 4:32:06 PM
heating & cooling Report
Tue, Nov 12, 2013 at 4:27:17 PM
Page generation time: 0.0905
