Forums >> Revit Building >> Technical Support >> How to make a Color Scheme show up through a stair.
Fri, Sep 12, 2008 at 11:25:23 AM | How to make a Color Scheme show up through a stair.
kevbo205
Does anyone know how to make a color scheme show up through stair treads?  I can change the color scheme to foreground but I don't want the colors to show through the walls.
Fri, Sep 12, 2008 at 11:54:17 AM | How to make a Color Scheme show up through a stair.
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
The only way I can think of is to trace your stairs with detail lines and then hide the stair element.
Fri, Sep 12, 2008 at 2:13:39 PM | How to make a Color Scheme show up through a stair.
JRMello
Wow, I thought for sure that Override the graphics to Transparent would have worked, but I just tried it before answering and it doesn't. You can linework it once it's transparent, but you can't select the whole stair at once so you have to go piece by piece which is annoying. Yet another flaw I suppose.
Fri, Sep 12, 2008 at 3:03:47 PM | How to make a Color Scheme show up through a stair.
alabaster2513
3.5 Stars: 25 Votes
yeah the only real basic way is to set your cut place in your view range to like 1/4" a.f.f. but then that just screws everything else up. too bad a plan region doesnt work either.
Mon, Sep 15, 2008 at 3:11:29 AM | How to make a Color Scheme show up through a stair.
tim123
4 Stars: 19 Votes
I can overide the graphics in view and turn the stair transparent - this seems to work for me.  See attached image.
Mon, Sep 15, 2008 at 10:44:05 AM | How to make a Color Scheme show up through a stair.
alabaster2513
3.5 Stars: 25 Votes
Your Revit is more majical than mine, I have tried that a few different ways but my stair just dissapears in the color fill.
Will you post that file so people can see how you did it?
Edited on: Mon, Sep 15, 2008 at 10:45:16 AM
Mon, Sep 15, 2008 at 11:23:35 AM | How to make a Color Scheme show up through a stair.
tim123
4 Stars: 19 Votes
I've tried to recreate that without success until I realised that I had opened Revit 2008 this morning to try it out.  Works in 2008 but not 2009.  I'm trying to figure out why - I'll get back when I find out.
Mon, Sep 15, 2008 at 11:51:33 AM | How to make a Color Scheme show up through a stair.
tim123
4 Stars: 19 Votes
I cannot see an option to make this work.  I thought that the solid fill may be set as opaque but this is not the problem.  An alternative is to overide the stair graphics - see attached images.
color scheme disappear
Fri, Sep 24, 2010 at 7:49:22 PM
Color Scheme in Reflected Ceiling Plans?
Thu, Nov 20, 2014 at 10:16:01 AM
zone color scheme "help"
Wed, Sep 22, 2010 at 12:39:33 PM
new color scheme entry error
Thu, Sep 18, 2014 at 1:42:54 PM
12
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:38 AM
Page generation time: 1.0269
