Forums >> Revit Structure >> Technical Support >> wall sweeps
Fri, Sep 12, 2008 at 4:49:20 AM | wall sweeps
riazadam
hi there
please can some1 help me this. if i try to do a wall sweep with 2 different profiles the 1st profile always changes to what the 2nd profil is so then all the sweeps become the same.
Fri, Sep 12, 2008 at 5:49:17 AM | wall sweeps
4 Stars: 205 Votes
Hi, if you create a family to create your Wall Sweep with "Generic Profile" or "Generic Profile-Hosted" you will see you only can drew ONE Profile, so there is the problem you have, in that case my advise is Cryingand i do this) create a family with "Generic Model FACE based" or "Generic Model Wall Based" to create this sweep, with parameters of lenght, with and so one to be paramétric and you can control your sweep or use "create in place" to do what you want..., i don't know what kind of sweep are you trying to do, so, i can tell Exactly the best solution to your problem, by the way, did you solve the problem you have with "Muslam Mesquit", the "Dome Roof Cupola"??
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Wall sweeps line weight
Wed, Apr 30, 2008 at 10:59:05 AM
Wall Sweeps
Sun, Jul 12, 2009 at 1:54:07 PM
13
Page generation time: 1.5981
