Forums >> Revit Building >> Technical Support >> Imaginary Surfaces
Thu, Sep 11, 2008 at 6:36:47 PM | Imaginary Surfaces
danpooler
I work for a Airport Developer. Everything we build has to fit under these imaginary surfaces for obivous reasons.  What I'd like to do is build these imaginary surfaces in Revit so i can build my hangars and office buildings then place them "hopefully" under this imaginary surface.  Here's a pdf I found online that can explain it a little better:
http://www.dot.ca.gov/hq/planning/aeronaut/documents/PT77_Ism%20Layout1%20(1).pdf
OK my question is how do I build a surface... I'd like to be able to see through this surface like this image shows:
http://www.openairport.org/images/oa_ge_outview.jpg
I was trying to use a roof command although it would a huge roof :-)  What would you use to create this "imaginary surface in Revit???  This surface would start at a surface point and have a 7:1 Slope. I'm also not sure how to create that slope in Revit either.
I'm using Revit Architecture 2009 and I just finished the essentials class on 9/10/2008
 Thanks for any help at all!
Thu, Sep 11, 2008 at 6:44:52 PM | Imaginary Surfaces
Belinski
4 Stars: 5 Votes
You could use transparent walls and make them huge.
Or, you could use massing
Thu, Sep 11, 2008 at 7:55:28 PM | Imaginary Surfaces
danpooler
Is there a material out there that would be see thru?  I'd like to make these a red tint...
Thu, Sep 11, 2008 at 11:55:50 PM | danpooler
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting danpooler from 2008-09-11 19:55:28
"Is there a material out there that would be see thru?  I'd like to make these a red tint..."
you can use any color, just adjust the opacity to make it transparent.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Sep 12, 2008 at 4:24:04 AM | Imaginary Surfaces
4 Stars: 205 Votes
Create a mass on that and give the material, you can choose "Glass Red" , go to materials>glass, you will see the Red Glass....
Fri, Sep 12, 2008 at 4:12:31 PM | Imaginary Surfaces
danpooler
I'm not sure why I'm having such a difficult time with the massing.  I can only extrude this from floor plan 1 to the desired height.  but in reality I should be drawing a triangle in the north elevation and extruding it but I haven't been able to do this.  I thought I could extrude and then rotate the entire mass on its side. Any suggestions at all?
Sat, Sep 13, 2008 at 4:41:39 AM | Imaginary Surfaces
4 Stars: 205 Votes
Hi, see the video: http://screencast.com/t/4tZDHxjo07
Sun, Sep 14, 2008 at 11:15:14 PM | Imaginary Surfaces
danpooler
Typhoon, Thank you so much for the help!! I will try it out as soon as I can! Thanks again!!!
Mon, Sep 15, 2008 at 9:29:07 AM | Imaginary Surfaces
danpooler
New Guy...
Thu, Sep 11, 2008 at 6:33:25 PM
Angular surfaces
Fri, Oct 16, 2009 at 2:23:30 PM
Turning floor surfaces off for individual floor elements?
Thu, Jun 29, 2006 at 1:31:20 AM
How to take quantities from painted surfaces?
Tue, Oct 10, 2017 at 1:00:43 AM
import dwg surfaces into Revit
Fri, Mar 6, 2015 at 1:56:09 PM
Page generation time: 0.0386
