Forums >> Community >> Newbies >> New Guy...
Thu, Sep 11, 2008 at 6:33:25 PM | New Guy...
danpooler
Just finished the Revit Essentials Class... Love the program but everything I learned doesn't quite fit into what I'll use it for.  We only touched site layout for about 10 minutes out of the 24 hours in the class... I will get more training but for now I'll ask around and try and see what I can learn on my own.
Basically I work for a Airport Developer. Everything we build has to fit under these imaginary surfaces for obious reasons.  What I'd like to do is build these imaginary surfaces in Revit so i can build my hangars and office builds then place them "hopefully" under this imaginary surface.  Here's a pdf I found online that can explain it a little better:
http://www.dot.ca.gov/hq/planning/aeronaut/documents/PT77_Ism%20Layout1%20(1).pdf
 OK my question is how do I build a surface... I'd like to be able to see through this surface like this image shows:
http://www.openairport.org/images/oa_ge_outview.jpg
I was trying to use a roof command although it would a huge roof :-)  What would you use to create this "imaginary surface in Revit???
I'm using Revit Architecture 2009 and like I said just finished the class on 9/10/2008
Thanks for any help at all!
Thu, Sep 11, 2008 at 11:53:25 PM | New Guy...
coreed
coreed Avatar
4 Stars: 16 Votes
looks like you could use a simple mass extrusion w/ a transparent material applied.
Check out the Revit Masing Tools
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Just trying to keep my job
Tue, Jan 26, 2010 at 11:51:47 AM
New guy - initially exploring collaborating remotely with large Revit projects
Wed, Mar 5, 2008 at 1:57:05 PM
newb, FNG, howdy
Thu, May 30, 2013 at 9:34:55 AM
New guy with question
Fri, Dec 28, 2007 at 9:38:28 AM
The New Guy
Wed, Feb 28, 2018 at 6:02:49 AM
Page generation time: 0.3287
