14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Elevation View for Window Schedule Not Dimensioning
38 Posts No Rating |
Revit 2009 I have seen on the forums that the best way to create a window schedule is to create an elevation view of the window then hide all other elements but the window. I have done this with the elevation tag that automatically alignes to face of window (so I thought). The tag apparently is not parallel to the face of window and cannot accept dimension lines as a result. How can I make these elevation callouts parallel to dimension off? Thanks -J
Create a new elevation. The elevation marker will try to snap to be perpendicular to model objects such as the door or window. Alternatively, you should be able to rotate the elevation marker to align with the window.
DOOR SCHEDULE with ELEVATION VIEW |
Tue, Jul 8, 2008 at 2:01:29 AM
How do you add Window Elevation to Window Schedule |
Fri, May 25, 2012 at 10:52:33 AM
Window schedule |
Wed, Apr 18, 2007 at 5:28:36 AM
window schedule |
Mon, Mar 6, 2006 at 1:35:19 PM
LOOKING THROUGH THE WINDOW, SCHEDULE |
Sun, Dec 19, 2004 at 7:03:39 PM
