Forums >> Revit Building >> Technical Support >> editing room boundaries
Thu, Sep 11, 2008 at 2:04:22 PM | editing room boundaries
Chicago2
1 Stars: 1 Votes
After a room is defined, is there a way to select that room and modify the outline of the boundaries to include such areas as closets, hallways, showers, etc?  I couldn't make a door non room-bounding, but I could make the wall, but that doesn't work in most instances as walls are most likely shared by other rooms, etc. Using 2009.
Thu, Sep 11, 2008 at 2:15:37 PM | editing room boundaries
4 Stars: 205 Votes
Yes you can, go to "Room and Area" then click in "Area Boundary" and draw the new boundary, you can trim the lines of boundaries, delete, create new ones...
Thu, Sep 11, 2008 at 2:27:28 PM | editing room boundaries
Chicago2
1 Stars: 1 Votes
Do you have to create an Area Plan to edit the boudaries?  I was trying to keep the S.F. info on the regular first floor plan and not have to print another sheet just for this.
Thu, Sep 11, 2008 at 2:40:26 PM | editing room boundaries
Whoa now....   Rooms and areas are really too seperate things so don't confuse them.
You can do area plans to get gross / net building areas and they are easily changed.  You can define the boundaries by pointing to walls or by drawing them.
Room definitions are a different horse altogether.  They really are NOT used in area schemes.  They are typically defined by room bounding elements like walls but you can also have room seperation lines to define them.  If you want rooms to combine (like when you want to include a closet in a bedroom) but they are dividedby a wall, you can turn off the room bounding switch for the wall bewteen the two rooms if it is only between those two rooms.
Thu, Sep 11, 2008 at 2:47:53 PM | editing room boundaries
Chicago2
1 Stars: 1 Votes
I'm glad areas and rooms are separate because I really don't want to go to the trouble of creating each room in an area plan.  However, we're back to the start of my question - can you simply edit room boundary lines when they are already defined?  Making a wall non room-bounding does not suffice, as that wall may be shared with other rooms.  Room separation lines do not seem to be able to expand the room, just make it smaller.  Ideally I'd like to be able to enter into a sketch mode when editing room boundaries in order to edit them, but I'll settle for the ability to make doors non room-bounding......
Thu, Sep 11, 2008 at 2:57:09 PM | editing room boundaries
Unless you turn off the room bounding of the walls they will still be active.
Room boundry lines are just that .... lines - edit - add then in the same manner.
Thu, Sep 11, 2008 at 2:58:04 PM | Typhoon
NKramer
4 Stars: 9 Votes
Quoting Typhoon from 2008-09-11 14:15:37
The area boundry actually creates an area not a room; 2 different catagories. As to how you can add/ removes areas from a room object you would have to use the room bounding option for the walls. If the wall is shared amongths multiple rooms then you would probably need to split the wall so that one part can be bounding and the other not...
HTH
Nick
Thu, Sep 11, 2008 at 3:07:30 PM | editing room boundaries
Chicago2
1 Stars: 1 Votes
If a room is defined, when you select it, a colored boundary appears....can you edit those lines defining that room boundary?  I'd like manipulate the shape to include a closet.  Making the wall non room-bounding is not enough.  The room separation command is not enough.
Thu, Sep 11, 2008 at 3:14:59 PM | Chicago2
NKramer
4 Stars: 9 Votes
Quoting Chicago2 from 2008-09-11 15:07:30
"If a room is defined, when you select it, a colored boundary appears....can you edit those lines defining that room boundary?  I'd like manipulate the shape to include a closet.  Making the wall non room-bounding is not enough.  The room separation command is not enough."
Those are your only 2 options. If you want to go off the room reservation then you could use area plans which will allow you to sketch a series of lines to define an area.
Otherwise split walls, use the room bounding/ not bounding and room seperation lines. If you need a room bigger then make the wall not bounding and add in the nessisary boundry lines.
You would need to post an example to show why this is not an option as it is the way that the rest of the world is creating their rooms in revit...
Nick
Edited on: Thu, Sep 11, 2008 at 3:41:11 PM
Thu, Sep 11, 2008 at 3:18:50 PM | editing room boundaries
4 Stars: 205 Votes
WWub, i don't understand, what he ask and i quote is "After a room is defined, is there a way to select that room and modify the outline of the boundaries to include such areas as closets, hallways, showers, etc?" - what i understand in this question is if you have a room and there are closets, W.C and so one, and when you place an Area in this room and "he" want to include in the same room the area of closets and W.C. you can edit the area boundary of that room and create a new one wich include what he want (areas of closets, hallways, showers,etc) in one Area.... Am i missing the question?
Edited on: Thu, Sep 11, 2008 at 3:34:00 PM
Thu, Sep 11, 2008 at 3:29:03 PM | editing room boundaries
Chicago2
1 Stars: 1 Votes
That was/is my question.  But i guess the split wall technique is my best choice.  Thanks for all the replies.
Wed, Aug 1, 2012 at 2:07:00 PM | editing room boundaries
Triggos
Hi everybody. I have a similar issue. I use Revit Arch 2012. I created a room within a set of perimeter walls. My project required to move one of those walls a few feet to one side. After moving that wall, the room boundary remained in the former wall position and did not move along with the wall. Is there a way to edit that room boundary outline to match the new location of the moved wall?
Thanks in advance,
Wed, Aug 1, 2012 at 3:26:55 PM | editing room boundaries
#13
If your rooms are bounded by walls that have the room bounding turned on, then you are done.  (There are only a few cases where I turn off room bounding.)  Remember - You can set this to ceter of wall or face of wall.
If you sketched your rooms using the room boundry line, then you have to edit the sketch yourself.
Fri, Aug 3, 2012 at 11:06:32 AM | editing room boundaries
#14
Triggos
Hi WWHub, is the sketch mode also for room boundaries? I thought it was only to create room areas on area plans....do you mean room separation lines????.....because I can't find that sketch mode for room boundaries....thanks again...
Fri, Aug 3, 2012 at 11:32:52 AM | editing room boundaries
#15
We will say this again - Areas and area plans are NOT the same as plans with ROOMS.
I said "...If you sketched your rooms using the room boundry line, then you have to edit the sketch yourself."  I should not have said sketched.  I will rephrase this.
If you defined your rooms using room bounding lines, you would have to edit thoes.   Better?
Room boundaries woun't properly display
Tue, May 15, 2018 at 3:08:14 AM
Revit 2012 - Edit Room Boundaries
Tue, Jul 5, 2016 at 2:42:16 PM
11
Any way to automaticaly find room boundaries to make finishing floor?
Wed, Sep 17, 2014 at 8:13:11 AM
room boundaries
Mon, Jun 4, 2007 at 2:42:08 PM
Room Boundaries limited?
Fri, Jan 30, 2015 at 5:19:55 PM
Page generation time: 1.9450
