Forums >> Revit Building >> Technical Support >> editing dimension line
Wed, Apr 27, 2005 at 1:48:10 PM | editing dimension line
yoiyoi
i would like to edit a dimension line to add some annotation eg. edit 50' dimension line to say ' 50' +/- to match existing' how do i do that? thanks
Wed, Apr 27, 2005 at 1:53:05 PM | RE: editing dimension line
arnosandoval
5 Stars: 3 Votes
If you click on the properties of the dimension line, you will have the opportunity to add annotation either as a suffix or prefix. HTH
Removing/editing single dimension in dimension string
Wed, Aug 26, 2009 at 7:12:02 AM
Dimension line fixed distance from an Object
Tue, Aug 22, 2017 at 8:18:26 AM
Hidden dimension segment
Mon, May 3, 2010 at 9:06:52 AM
Dimension Editing
Fri, Jan 26, 2007 at 8:03:13 PM
Dimension This....
Tue, Aug 31, 2010 at 3:05:21 PM
Page generation time: 3.3358
