Forums >> Revit Building >> Technical Support >> distance between text and leader lines able to be changed?
Thu, Sep 11, 2008 at 11:46:00 AM | distance between text and leader lines able to be changed?
ekhozindar
take a look at the picture below, i wanted to know if its at all possible to make the leader lines from text come closer to the actual text. when there is text with a leader starting from the south or north side of the text, it always looks far away than what my preference is.
 knowing that text is a system family, i'm going to assume the answer is no, but it doesnt hurt to ask.
Thu, Sep 11, 2008 at 11:58:03 AM | distance between text and leader lines able to be changed?
Belinski
4 Stars: 5 Votes
Hi, this thread might help you out.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=11720
Fri, Sep 12, 2008 at 10:20:21 AM | distance between text and leader lines able to be changed?
ekhozindar
thanks that did actually help a bit. I had never really looked into tagging before. Question though, when you tag all not tagged, is there an option to omit items you dont want to tag? instead of literally having to tag EVERYTHING and going back to delete what you dont want?
Distance from leader to text... Revit 2010
Tue, Jun 1, 2010 at 9:13:51 AM
Distance between Leader Arrow and Font
Wed, Dec 16, 2009 at 12:37:35 PM
leader lines
Mon, Jan 19, 2009 at 2:39:06 PM
EDITING TEXT LEADER ARROWHEADS AND LINES
Thu, Aug 14, 2008 at 3:21:20 PM
drawing a leader/arrowhead without text?
Mon, May 31, 2010 at 10:54:51 AM
Page generation time: 0.7755
