Forums >> Revit Building >> Technical Support >> Room Tags disappeared when 08 file saved in 09!
Wed, Sep 10, 2008 at 11:28:05 AM | Room Tags disappeared when 08 file saved in 09!
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I checked the visibility graphics and the room tags are checked.  I went to the drafting tab and hit the "tag all not tagged" button for room tags.  Nothing.  Is there some known glitch when you take a project from 2008 to 2009 Revit?  I have the latest build installed so everything should be up to date.
Wed, Sep 10, 2008 at 12:18:10 PM | Room Tags disappeared when 08 file saved in 09!
JRMello
I had a 2008 project that I converted to 2009 and the tags made the transition fine. So, I don't think it's a glitch accross Revit 2009, but may be something specific to your copy or the project you're working in. Are the tags custom or anything like that?
Wed, Sep 10, 2008 at 1:11:22 PM | Room Tags disappeared when 08 file saved in 09!
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
The room tags were modified slightly but I tried using five different room tags and none appeared.
Room tags At Sections
Tue, Jun 12, 2007 at 2:46:10 PM
How to make room tags in a linked file visable?
Thu, Jul 30, 2015 at 1:12:22 AM
Linked file Room Tags
Wed, Apr 17, 2013 at 1:08:27 PM
2011 - Room Tags from a linked file
Thu, Aug 19, 2010 at 4:10:54 PM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Page generation time: 0.5926
