Forums >> General Discussion >> Revit Project Management >> how do wall with diferent width at the beginning in in the end?
Tue, Sep 9, 2008 at 4:43:15 PM | how do wall with diferent width at the beginning in in the end?
querosaber
for example in a old wall ?
thanks
Tue, Sep 9, 2008 at 4:45:41 PM | how do wall with diferent width at the beginning in in the end?
Belinski
4 Stars: 5 Votes
You have to either create your own wall type, or use to seperate walls to achieve this.
HTH
Wed, Sep 10, 2008 at 8:29:23 AM | how do wall with diferent width at the beginning in in the end?
4 Stars: 205 Votes
Estás a falar deste tipo de paredes antigas? (Are you talking about this kind of old walls?)
Wed, Sep 10, 2008 at 9:21:15 AM | how do wall with diferent width at the beginning in in the end?
querosaber
sim é dessas paredes ! como se podode fazer ? e por exemplo uma lareira ?
 Crying yes this is wall types? )
Wed, Sep 10, 2008 at 10:08:24 AM | how do wall with diferent width at the beginning in in the end?
4 Stars: 205 Votes
A Lareira vái ao "meu View Profile" e tens dentro dos meus "Object Uploads" uma Lareira feita no RAC 2008 100% paramétrica. (About the fireplace go to my "View Profile" and you have inside in my "Object Uploads" a Fireplace made in RAC 2008 100% parametric).
Quanto ás paredes, podes fazer de várias maneiras mas eu criei uma familia paramétrica no "Generic Model Wall Based" em que posso controlar a espessura da parede exterior e interior, largura e altura da abertura e tmb a largura  da abertura interior, depois foi só gravar com outro nome e criar outra familia para as portas, estas familias o k fazem é criar apenas a abertura igual á k vês na imagem anterior depois é só inserir a janela ou a porta, dependendo da familia.... (About the Walls, you can make that in severall ways but i create a parametric family in "Generic Model Wall Based" and i can control the with of the exterior and interior wall, width and height of the opening and too the width of interior opening, then it's just save with other name and create other family to the doors, this families what they do is just create an opening just like you can see in the image attached before then is just insert the window or door depend the family you want...)
Edited on: Wed, Sep 10, 2008 at 10:09:33 AM
Mon, Oct 6, 2008 at 10:05:06 AM | how do wall with diferent width at the beginning in in the end?
querosaber
thanks! obrigado pessoal!
 como vo noutro thread . a minha pergunta ´´ esemelhante a outro utilizador . por exemplo como faço estas paredes?
Mon, Oct 6, 2008 at 11:10:16 AM | how do wall with diferent width at the beginning in in the end?
4 Stars: 205 Votes
Acho k já respondi à tua pergunta no "Post" anterior... (I think I just awnser your question in the last post...)
Wed, Mar 2, 2011 at 5:40:26 AM | how do wall with diferent width at the beginning in in the end?
querosaber
e como faço ? faço um solido e subtraio da parede?
Wed, Mar 2, 2011 at 5:50:54 AM | how do wall with diferent width at the beginning in in the end?
4 Stars: 205 Votes
Não fazes um "Sólido" mas sim um "Void" e na categoria "Walls"
Wed, Mar 2, 2011 at 8:48:34 AM | Typhoon
Dafpfy
3.5 Stars: 11 Votes
Quoting Typhoon from 2008-09-10 10:08:24
 (About the Walls, you can make that in severall ways but i create a parametric family in "Generic Model Wall Based" and i can control the with of the exterior and interior wall, width and height of the opening and too the width of interior opening, then it's just save with other name and create other family to the doors, this families what they do is just create an opening just like you can see in the image attached before then is just insert the window or door depend the family you want...)"
Huh? i dont understand?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Beginning and End Stair Treads
Tue, Mar 31, 2009 at 3:16:55 PM
Wraping wall at end
Tue, Dec 9, 2014 at 12:48:22 PM
Wall Core Width in Schedule
Tue, Dec 2, 2008 at 1:10:22 PM
images when print have a diferent colors! why?
Wed, Dec 10, 2008 at 11:09:48 AM
create a wall sweep on an angled wall (gable end wall) (2017)
Wed, Aug 3, 2016 at 2:29:53 PM
Page generation time: 1.9919
