Forums >> Revit Structure >> Technical Support >> blending curves
Tue, Sep 9, 2008 at 2:15:06 AM | blending curves
3drulez
4.5 Stars: 2 Votes
i am a newbie to revit ,and hv been learning revit since 2 months.
i hav a problem with blending curves. i m trying to make a table cloth by blending a polygon with a series of curves.
but as i give "finish sketch" command the revit interface hangs.
Tue, Sep 9, 2008 at 3:40:56 AM | blending curves
4 Stars: 205 Votes
Hi and Welcome to Revit World, when you create a Swept Blend with a path spline and the 2 profiles ellipsoide and circle i.e., revit must process that transition -ellipse/circle along the spline and it take a few moments to process, but all depend the computer you have, processor, ram, O.S. and so one....
Mon, Oct 13, 2008 at 12:22:38 PM | blending curves
3drulez
4.5 Stars: 2 Votes
thanks typhoon... i left that option .. my pc doesnt allow that heavy a process...
Tensile Membrane Structures
Wed, Sep 29, 2004 at 7:08:23 AM
Revit 2018.2 Print to PDF Turning Curves into Polygons
Tue, Apr 17, 2018 at 12:30:39 AM
Multiple Curves and Angles with Sweep
Mon, Jun 24, 2013 at 1:34:46 PM
Roof fascia curves in plan and elevation
Sun, Dec 13, 2009 at 1:40:44 PM
blending a sweep (Modeling)
Fri, Dec 16, 2011 at 2:37:56 PM
Page generation time: 0.8624
