11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Curved whole in a wall?
35 Posts No Rating |
Hi! I want to do what I show in the picture I can do it but only with rectangular forms. thanks a lot
You can edit the profile of the wall. Select the wall and you should see "Edit Profile" in the options bar. If you need to do this for many walls, I wouldn't recommend using the Edit Profile. I would create a family and load it into your project. I use RAC2009, so here is a family I created just then.
- Core 2 Duo E8400 3ghz
- 756mb Nvidia 9600GSO 256bit
- 6gb Kingston RAM 800mz DDR2
- Windows XP Service Pack 3 32-bit
55 Posts No Rating |
to create a hole like that, I think you can do it in two ways.. First, click the edit profile button in option bar (when you select wall instance), and then you can create your desired hole shape in sketch mode.. and if you want to make it as a door, you can create it in Door Family, change the opening shape into archway door like that... attached is the hole I create using edit profile.
ALC, "I can do it but only with rectangular forms", because you are making a "OPENING" isn't? well, openings work only in the Rectangle shape, to do that do like TIMBO said "pick the wall, edit profile and create the shape like in your picture, there must be only 1 "polyline" closed...
I did it1 I didn't knwo that command Thanks a lot!
Curved wall and curved window |
Tue, Jun 23, 2015 at 8:23:19 AM
Wainscoting in a curved wall |
Wed, May 27, 2015 at 9:51:14 AM
couter top for a curved wall |
Mon, Nov 22, 2010 at 5:02:47 PM
Complex Curved Walls - please help |
Wed, Mar 25, 2009 at 5:26:10 PM
How to do a vertical reveal in a sweep in a curved wall? |
Thu, Oct 22, 2009 at 2:04:26 PM
