Forums >> Revit Building >> Technical Support >> imaginary sheets in the index
Mon, Sep 8, 2008 at 6:18:28 PM | imaginary sheets in the index
shamilton
I need my drawing index to reflect sheets that are not actually in my project (aka consultant drawings being created by someone else in another program). Is there a way to add them to my index without creating a blank sheet?
Mon, Sep 8, 2008 at 6:31:12 PM | imaginary sheets in the index
ArchMERK
Blank sheets have been the only workaround I've been able to find, other than creating a non-revit table.  I have a letter sized titleblock with just the sheet name and number on it that I use for those.
Mon, Sep 8, 2008 at 6:33:55 PM | imaginary sheets in the index
shamilton
Have you had problems with these blank sheets taking up a lot of memory?  I'm going to have over 100 blank sheets if I go this route.
Mon, Sep 8, 2008 at 6:59:36 PM | imaginary sheets in the index
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
It shouldn't make your file any larger. Just make the sheet and delete the titleblock, it will show up in the index still.
Mon, Sep 8, 2008 at 7:06:45 PM | imaginary sheets in the index
shamilton
Mon, Sep 8, 2008 at 7:08:30 PM | imaginary sheets in the index
shamilton
I swear I only posted that memory question once - thanks to both of you for your help!
Sheet / Drawing Index / List Check Box
Thu, Dec 18, 2008 at 8:48:15 AM
Combine multiple sheets into a single PDF file per THE SHEET INDEX
Fri, Jul 31, 2015 at 3:00:27 PM
Imaginary Surfaces
Mon, Sep 15, 2008 at 9:29:07 AM
index of drawings
Thu, Nov 15, 2007 at 6:43:06 PM
Revit 2016 - Multiple Drawing Sets in Sheet Index
Fri, Jan 12, 2018 at 10:38:33 AM
Page generation time: 0.0978
