10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> walls on different levels not even
2 Posts No Rating |
I have exterior walls on levels 1 and 2 with different thickness (15" and 12", for example)... and I try to line them up so the outside of the walls is seamless. But in a 3d or elevation views, they are not completely aligned. How can I get the outer surfaces to snap to each other? I'm using revit architecture 2009. Thanks for any help, Brendan
55 Posts No Rating |
I'm not quite understand, do you mean there's a line between the thick wall and the thin wall? if so, I think you don't have to worry, when you render it, the line will be gone. attached is my trial for your case. I hope what I assume for your problem is right... I create bottom wall 500mm thickness and the top wall is 140mm, both using Concrete Material. I'm using align tool to make both exterior face wall aligned.
2 Posts No Rating |
I guess align does work. I tried it unsuccessfuly before, but it's apparently just a matter of the walls being close enough for align to work. Thanks.
u can better try out for align it works
Chirag C. Pawar Cad Solution Application Senior Engineer KLGSystel Ltd. India 301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel .: +91 22 409 16777. Extn. - 718Fax .: +91 22 275 76461.Mob .: +91 99 698 66851.Email.: chiragp@klgsystel.com Web .: www.klgsystel.com |
walls look different on different levels |
Thu, Mar 11, 2010 at 2:38:19 PM
VG Filtering Walls by Different Base Contraints |
Wed, Apr 1, 2015 at 10:22:28 AM
Join walls command for a group. Issue |
Sun, May 13, 2018 at 11:06:02 PM
Placing Electrical on Walls of different levels that are in same view |
Thu, Mar 5, 2015 at 9:41:25 AM
Levels, Disappeared. [ 1 2 ] |
Sun, Sep 24, 2017 at 7:44:33 AM
16
