Forums >> Revit Building >> Technical Support >> Trim on slanted column
Fri, Sep 5, 2008 at 2:34:39 PM | Trim on slanted column
baumansara
I have a square craftsman style column that I made with slanted walls.  (see attached file)  I need to add trim at the four corners of the portion that is siding.  I tried using a solid form, solid blend to make it.  It worked, but it wouldn't let me finish the in place family.  I got a message saying it can not be copied ???  Any suggestions on how to make the vertical trim for this column?
Thanks!
Sat, Sep 6, 2008 at 11:03:03 AM | Trim on slanted column
4 Stars: 205 Votes
Hi, really what are you trying to do? it's something like the pic. attach?
Sun, Sep 7, 2008 at 4:18:30 PM | Trim on slanted column
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Try doing all the sweeps in the same family and do each of them independantly using pick path rather than copying them or using a Blend and that should solve your issue.  Alternatively, I would create an external family blend with adjustable parameters for the offset and then place them independantly.  Its always better to create families externally if they are repeated in any way...
HTH.
Regards,
Chris.
Mon, Sep 8, 2008 at 1:20:01 PM | Trim on slanted column
baumansara
yep, that's what I was trying to do....thanks.
Slanted Columns in Revit LT ??
Wed, Mar 13, 2013 at 8:28:19 AM
Mirroring a slanted column
Mon, Mar 10, 2014 at 7:50:04 PM
Can't mirror L Angle slanted column
Mon, Apr 11, 2011 at 9:52:21 AM
Column trim
Tue, Mar 29, 2005 at 2:48:36 PM
Slanted column
Sat, Nov 5, 2005 at 9:44:09 PM
Page generation time: 0.1596
