Forums >> Revit Building >> Technical Support >> Ceiling Height in Room Tag?
Fri, Sep 5, 2008 at 12:13:12 PM | Ceiling Height in Room Tag?
shsbsk
I'm trying to make Room Tag that has Ceiling Height as well.
In the room schedule, I could create ceiling height by using Volume/Area formula, but can I put this formula in the tag some how, so it will appear when I place the tag?  If yes, how can I do that???
Fri, Sep 5, 2008 at 3:02:58 PM | Ceiling Height in Room Tag?
No - no formulae in tags.
Sun, Sep 7, 2008 at 11:01:41 PM | Ceiling Height in Room Tag?
psymon
psymon Avatar
3.5 Stars: 6 Votes
use spot elevations - these will update dynamicaly...
Wed, Sep 10, 2008 at 10:10:59 AM | Ceiling Height in Room Tag?
shsbsk
WWHub:  Thank you for your information.  I thought I can add formula by using "Family Types".
psymon:  I don't know how/where to use spot elevation because I have never done spot elevations, but I'll try.  Thank you for your input!
Wed, Sep 10, 2008 at 10:36:35 AM | Ceiling Height in Room Tag?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I would try adding the height parameter to your room scedule as a shared parameter then add it to the tag? I don't know if it would work but it's worth a shot eh?
Wed, Sep 10, 2008 at 7:04:19 PM | Ceiling Height in Room Tag?
psymon
psymon Avatar
3.5 Stars: 6 Votes
" would try adding the height parameter to your room scedule as a shared parameter then add it to the tag". This method will not automatically update and will only show a manually entered value
Spot elevations can be made relative to a level and thus can show for example CL + 2700.
Room Name w/ manually entered Ceiling Height
Mon, Jan 19, 2009 at 3:50:30 PM
How can I add clear Height (floor to bottom of slab above) in a Room Tag?
Sun, Aug 21, 2016 at 3:08:14 AM
Ceiling height in Room Tag
Thu, Jan 22, 2009 at 3:00:37 PM
Room Tag + Ceiling Tag Hybrid
Wed, Jan 21, 2009 at 8:40:08 PM
Ceiling height in Room Schedule
Sun, Apr 5, 2009 at 12:44:47 PM
Page generation time: 1.2113
