Forums >> Revit Building >> Technical Support >> 8' ceiling in a 6'2 t.o.w.
Fri, Sep 5, 2008 at 11:39:54 AM | 8' ceiling in a 6'2 t.o.w.
Warchitect
4 Stars: 5 Votes
Revit 2009
Got a room with a 4 12 hyp roof.
the top of wall is 6'2, but the ceiling is at 8' hi, so you have that little but of sloped roof at the peremeter of the room. how do you draw this? I tried the ceiling tool, it places  line in the section, but no framed ceiling with thickness. do I try to build a floor 8' off the regular floor and try to connect the geometries?
Sat, Sep 6, 2008 at 11:21:56 AM | 8' ceiling in a 6'2 t.o.w.
4 Stars: 205 Votes
Hi, draw the ceilling then in properties you can change the heigh and the tickness with different materials and after in section you can use the "Join/Unjoin" command... see the pic. attached, it's what do you want?
Sat, Sep 6, 2008 at 3:49:35 PM | 8' ceiling in a 6'2 t.o.w.
Warchitect
4 Stars: 5 Votes
so I was able to get thickness by changing the type of ceiling. but there still is no thickness option in the properties dialog...So im not sure how to get thickness still.
M
Sat, Sep 6, 2008 at 3:50:38 PM | 8' ceiling in a 6'2 t.o.w.
Warchitect
4 Stars: 5 Votes
nvm i found it. thanks
4' - 4' Accostical Ceiling Tile - Joining Soffit horizontal wall with vetical
Thu, May 14, 2009 at 12:50:09 PM
How to create a 600x600 ceiling
Mon, Jul 18, 2005 at 11:31:08 AM
Ceiling height in Room Tag
Thu, Jan 22, 2009 at 3:00:37 PM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Ceiling View Ranges: 2
Sat, Feb 23, 2008 at 9:25:24 PM
Page generation time: 0.4514
