Forums >> Revit Building >> Technical Support >> editing walls
Tue, Apr 26, 2005 at 10:39:09 PM | editing walls
yoiyoi
i have a composite wall with a brick veneer. in a section view i would want to be able to extend the brick veneer to meet the foundation footing. i have not found any means of doing this in the edit assembly dialog box could anyone provide a step by step approach of achieving this. thanks
Tue, Apr 26, 2005 at 11:00:20 PM | RE: editing walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Select a composite wall and go to its properties, Click edit/New Then edit structure. Turn on the preview and change it to section as opposed to floor plan. Select modify and pick the bottom edge of the brickwork. A padlock should appear. Unlock it. Now click okay, until all dialogue boxes are gone. Select one of your brick veneer walls and go to its properties, you should now have a parameter for bottom extension distance. Enter in a negative value for how far you wish the brickwork to extend down... There you go... HTH.
Wed, Apr 27, 2005 at 1:01:15 AM | RE: editing walls
yoiyoi
thx a bunch , spotty
Editing how walls are attached to floors
Fri, Aug 1, 2014 at 7:37:38 AM
editing group....
Wed, Jul 26, 2006 at 2:45:37 AM
Editing Parameters of Walls embedded within Groups (Bug?)
Fri, Dec 1, 2006 at 11:58:48 AM
Editing Keynotes
Tue, Sep 14, 2010 at 9:47:45 AM
Editing request
Tue, Jun 29, 2021 at 2:20:20 AM
Page generation time: 0.3030
