Forums >> Revit Structure >> Technical Support >> Quatifying walls
Thu, Sep 4, 2008 at 3:59:57 AM | Quatifying walls
Spawn
does any one know if you can schedule a wall so that you can get a total amount of bricks ect
Thu, Sep 4, 2008 at 4:12:49 AM | Quatifying walls
4 Stars: 205 Votes
You can create a shedule to walls to quantify "Family type, Height, Lenght, Area..." but "total amount of bricks"??? do you want to know the total of the wall in model in "Family Brick"?
Thu, Sep 4, 2008 at 4:21:36 AM | Quatifying walls
Spawn
the amount of bricks that would be used to build the wall.
can a parameter be added to a schedule that would work out an amount?
example in one square meter of a 115mm thick wall you will have +/- 52 bricks (an elevation View)
Thu, Sep 4, 2008 at 4:32:05 AM | Quatifying walls
4 Stars: 205 Votes
That's what i am affraid, i really don't know if it's possible, i never need that, but maybe Creating "Shared" parameters with some formulas with Areas and constantes, maybe, i really don't know, i will try to do that.... Mean while ANYONE?????
Thu, Sep 4, 2008 at 4:34:31 AM | Quatifying walls
Spawn
ok thanx will try that
Thu, Sep 4, 2008 at 12:56:55 PM | Quatifying walls
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
Just add a calculated value in your takeoff showing "Area/# of bricks per unit" and that will give you the total number of bricks for that wall type
cad.web.print
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:42 PM
Walls
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool?
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls.
Sun, Dec 14, 2014 at 4:58:35 PM
Page generation time: 1.0464
