Forums >> Revit Building >> Technical Support >> How to make a Swimming Pool?
Sun, Apr 24, 2005 at 3:42:15 PM | How to make a Swimming Pool?
Cypher
Good Evening Everybody Smile I would like to do add a swimming pool to my house but I have no idea how to do it... Could somebody help me? Thanks a lot. Cypher
Sun, Apr 24, 2005 at 5:49:54 PM | RE: How to make a Swimming Pool?
arquia
2.5 Stars: 9 Votes
hi! you can make a swimming pool, creating a level of base to your swimming pool and after you build the walls and after you create a mass with water material. its possible create a transparency for you water line.
arquia@sapo.pt
Tue, Apr 26, 2005 at 5:16:34 PM | RE: How to make a Swimming Pool?
Cypher
hi!
you can make a swimming pool, creating a level of base to your swimming pool and after you build the walls and after you create a mass with water material. its possible create a transparency for you water line.you create a mass with water material ---> How can I do to choose a material and apply it on something?
Tue, Apr 26, 2005 at 7:07:09 PM | RE: How to make a Swimming Pool?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I typical model the water as a floor, to apply the material i just create a new floor type then change the structure material to a preset material. Site - Water would most likely already be setup in your file. You can edit this to change transparency or duplicate it to create a new material. HTH.
Tue, Dec 8, 2009 at 4:04:57 AM | How to make a Swimming Pool?
MichaelJones
Parametric Swimming Pool NOW available at http://www.revit-content.com/content/09-5847994-Swimming_Pool.htm
Edited on: Tue, Dec 8, 2009 at 4:08:26 AM
Sun, Sep 12, 2010 at 11:17:51 PM | How to make a Swimming Pool?
ChokeSlam
You might consider first if you want a chlorinated pool (common type) or salt water pool.
My aunt installed a swimming pool about 3 years ago only to find out that her children have chlorine allergy
cover above ground|| winter pool cover
Mon, Sep 13, 2010 at 11:40:38 AM | How to make a Swimming Pool?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I have made several pools, I generally model in place with a sweep blend. I model the water as Mr. Spot has suggested.
Mon, Jan 28, 2013 at 7:43:25 AM | How to make a Swimming Pool?
Alvaro8100
A magnificently constructed swimming pool is a dream to all.However once you have decided to construct a pool, there are so many thoughts that walk in randomly.Me and my wife also planning making an Endless Pool and situating it in our garage.
I read out interesting and informative ideas.This information will be helpful for me.Thanks everyone...
pool accessories
Tue, Jun 28, 2016 at 8:58:55 PM | How to make a Swimming Pool?
SmarterArchitect
For a simply step-by-step video Revit tutorial on how to create a Revit pool, click on the following link.
Revit Pool
^^ This is not a normal youtube address so beware users - WWHub
update: I have since found out that the "youtu.be" is some sort of domain shortener so disregard my caution.Edited on: Wed, Jun 29, 2016 at 7:08:56 AM
Edited on: Wed, Jun 29, 2016 at 8:17:44 AM
Wed, Jun 29, 2016 at 12:56:45 PM | How to make a Swimming Pool?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
typically gunite pools have a 5" thick vertical wall for the upper 3 feet, at the top resides a bond beam 12" wide by 12" high, ususally this is tapered on the back side to the 5" shell. below this 3' depth, known as a springline the pool is curved in section so the deep end is typically 5' in radius, shallow end 2' radius down to 6" radius. upper portion of the pool can be created with a simple sweep. the lower portion is a little more complicated and is done with a sweep blend.
Wed, Sep 28, 2016 at 1:23:05 AM | How to make a Swimming Pool?
jenniferhorwitz
Nice ideas..
Get in contact with the professionals.
Swimming Pool
Tue, Jun 28, 2016 at 9:04:19 PM
Swimming Pool
Tue, Dec 8, 2009 at 4:11:28 AM
Swimming Pool
Mon, Jan 28, 2013 at 7:44:57 AM
swimming pool
Wed, Sep 15, 2010 at 12:54:01 AM
Swimming Pool?
Mon, Sep 20, 2010 at 12:24:42 AM
Page generation time: 0.7833
