Forums >> Revit Systems >> Technical Support >> 3D DWF export in Revit 2009 does not export identity data
Wed, Sep 3, 2008 at 6:48:27 PM | 3D DWF export in Revit 2009 does not export identity data
IngoRatsdorf
Hi.
I used to export 3D DWF files in revit 9.1 with all the element data (identity data, like comments, descriptions, etc), when I export a 3D DWF file in Revit 2009, all Identity data is not exported anymore. So when sending a model to the QS, he cannot access all the information I put into the model and makes it kind of superfluous....
Is there some kind of hidden configuration file for the export settings, because there are no options or settings anymore when exporting 3D DWF in Revit 2009...
Cheers,Ingo
Thu, Nov 19, 2009 at 12:01:43 PM | 3D DWF export in Revit 2009 does not export identity data
Hawkmoon36
I'd like to bump this thread. I'm using RAC2009 and would like to know the same info. I have custom identity data that I would like exported with the DWF file. Is there any way to include it?
Revit Identity Data export to Navis
Tue, Aug 30, 2022 at 6:23:11 AM
IFC export/import and "Identity Data"
Tue, Nov 5, 2013 at 6:04:10 PM
Revit 2012 - export DWF - corrupt dwf file
Fri, Aug 3, 2012 at 10:47:11 AM
Inconsistent data in DWF exports
Fri, Nov 20, 2009 at 7:13:48 AM
Export to DWF vs. DWG
Tue, Apr 24, 2012 at 3:52:31 PM
Page generation time: 1.4547
