Forums >> Revit Building >> Technical Support >> in a Site Plan
Wed, Sep 3, 2008 at 3:26:17 PM | Sidewalks in a Site Plan
timglass
What are good methods for building sidewalks in a site plan?
Thanks,
Tim
Edited on: Wed, Sep 3, 2008 at 3:28:46 PM
Wed, Sep 3, 2008 at 3:32:45 PM | in a Site Plan
4 Stars: 205 Votes
It all depend of the the shape and the model you want for your "Sidewalks", you can use sub-regions, depend, do you have some screenshots of what do you want?
Wed, Sep 3, 2008 at 6:16:29 PM | in a Site Plan
timglass
Okay, help me understand this:
I have a site plan.  I've created a topo map and placed the elevation of the points at -1'-0".  The top of the sidewalk should be at -6".  Now, I've used a subregion for the street, but that appears to be just a planar surface on top of the topo.  Sidewalks should be completely 3D, more like a slab with an odd looking footer at one end.
I've run into a semi-related issue:  There are apartments that set at 0'-0" top of slab.  I need to create a driveway slab that falls from the edge of the garage slab to the curb edge.  It seems impossible to make a floor or a subregion tilt, so how do I accomplish this?  3D massing object?
Thanks for all the help in advance.  Revit is an incredible tool, but I'm so new to it that some areas are both baffling and irritating.
Tim
PS - I should also add that this is not for a construction set.  They already have a set of construction documents.  This is only for visualization.
Edited on: Wed, Sep 3, 2008 at 6:29:34 PM
Thu, Sep 4, 2008 at 3:04:13 AM | in a Site Plan
tim123
4 Stars: 19 Votes
You can create a floor slab and give it the finish that you require.  Select the floor slab and a set of tools appear where you can set the heights at different points.  You can add additional points so that the floor does not have a flat surface.
Thu, Sep 4, 2008 at 3:32:17 AM | in a Site Plan
4 Stars: 205 Votes
Well TIMGLASS, like you said "They already have a set of construction documents.  This is only for visualization.", so you don't have any problem to edit the toposurface and change/edit the points and modeling the surface like do you want, i don't see what really you want to do but you can split several times the surface by zones and create new points and change the others and give differents materials to those "Split Surfaces" and/or create sub-regiond to accomplish the site, "It seems impossible to make a floor or a subregion tilt, so how do I accomplish this?  3D massing object?", Why not? you also can create a "Floor/Slab" and create new points in that and change the elevation points of your slabs to do what you need, you just said: "This is only for visualization."....
Thu, Sep 4, 2008 at 9:09:25 AM | in a Site Plan
timglass
Thanks for all the help, everyone.
site plan disappears intermittently
Thu, Mar 16, 2017 at 9:21:12 PM
Problem with Reigion Hatching on Site Plan [ 1 2 ]
Tue, Feb 25, 2014 at 4:19:15 PM
26
help!!! deleted site plan!
Fri, Aug 7, 2015 at 9:23:10 PM
13
Advice on creating a site plan
Mon, Jul 12, 2010 at 5:04:03 PM
invisible road carparks and landscape on site plan
Fri, Aug 28, 2009 at 6:44:33 AM
Page generation time: 0.5606
