Forums >> General Discussion >> Wishlist >> Mullions
Wed, Sep 3, 2008 at 1:29:50 PM | Mullions
dfitzladdy
5 Stars: 3 Votes
Horizontal and Vertical mullions need to join, rather than butting into each other, showing a line where the joint is.  Users should be able to JOIN mullions together, like walls and other families.  Currently, the only way I know around this is to draw a filled region to hide the joint, which is pretty time consuming and ridiculous for a whole building of storefront windows.
 PLEASE get this fixed, it's really silly that it doesn't already exist in Revit!
Apologies if a request to solve this problem has been posted before, but i haven't come across this in any of the forums.
Thu, Sep 4, 2008 at 8:51:52 AM | Mullions
JRMello
Using the Linework tool with <Invisible Lines> might be a little easier that using filled regions. Still not ideal, I know, but I hope it helps a bit.
Thu, Sep 4, 2008 at 9:22:57 AM | Mullions
dfitzladdy
5 Stars: 3 Votes
Yep, a little bit better, not quite there, but it will have to do.  Thanks!
Thu, Sep 4, 2008 at 9:43:19 AM | Mullions
Actulayy, there is a switch at the vertical /horizontal intersection that you can select to determine which muillon passes through.  The only joint showing, unless one mullion is not in the same plane as the other, is the vertical/hroizontal junction and that depend on thie switch.
To set which one is continuous, select the muillion and you will se a switch at each end in blue.
Adding mullions to a window
Wed, Dec 14, 2016 at 10:19:19 AM
Mullions within in panel family
Mon, Jun 12, 2017 at 2:32:28 PM
Curtain wall mullions
Fri, Jan 11, 2008 at 9:22:15 AM
Corner Mullions
Fri, Dec 6, 2013 at 11:05:58 AM
Different sized Mullions
Wed, Aug 7, 2019 at 5:48:08 AM
Page generation time: 3.6026
