Forums >> Revit Building >> Technical Support >> Cannot save or export rendering after it has completed
Wed, Sep 3, 2008 at 12:10:31 PM | Cannot save or export rendering after it has completed
abejayson
I am having trouble saving and exporting completed renderings.  I am using 2009 and rendering at BEST with 400 DPI (I know, excessive DPI, but I find the materials render more accurately with higher DPI).  Two things happen,
1:  The rendering completes, and is visible on screen in Revit, but I am unable to export or save to project, and suffer the agonizing defeat of returning to the model without a rendering.
Or:
2:  A dialog box pops up when I start the rendering saying I do not have enough memory for the rendering.
 Any help would be greatly appreciated.  Thanks
Wed, Sep 3, 2008 at 12:41:22 PM | Cannot save or export rendering after it has completed
4 Stars: 205 Votes
What is the caracteristics of your computer? OS system (32 64Bits?), RAM, Graphics, processor and so one? Did you upgrade to WEB UPDATE 20080602_1900?
Wed, Sep 3, 2008 at 2:37:56 PM | Cannot save or export rendering after it has completed
abejayson
System info:
OS:  Windows XP PRO v.2002 Service Pack 3
Machine:  DELL Optiplex 755, Intel core 2 duo cpu, E8200 @ 2.66 GHz, 2.66 GHz, 2.96 GB RAM
Graphics:  ATI Radeon HD 2400 PRO (0x94C3), internal DAC (400MHz), 256 MB memory, 32 Bits
I admit most of this is greek to me.
what is the web update you refer to, and if it is helpful where do I find it?
Thanks
Wed, Sep 3, 2008 at 3:14:39 PM | Cannot save or export rendering after it has completed
4 Stars: 205 Votes
Hi, the caracteristis, that's ok, the WEB UPDATE it's like a SP-Service pack for Revit 2009, you can check in this site: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=1101759
you can check in "WEB UPDATE ENHANCEMENT LIST (PDF)" the issues what this service pack solve, renders problems is one of them... after this you have the link to download the SP....
Wed, Sep 3, 2008 at 8:39:55 PM | Cannot save or export rendering after it has completed
vicozzio
Sorry Typhoon, when I copy paste the link you gave us... the page show this message :
The Page You Were Looking Was Not Found
Most likely the page or file you are looking for has been moved or updated. Please use the links below to find current information.
do you have any other link?
Thu, Sep 4, 2008 at 3:36:52 AM | Cannot save or export rendering after it has completed
4 Stars: 205 Votes
Well try this: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11017599
Tue, Dec 8, 2009 at 9:12:03 AM | Cannot save or export rendering after it has completed
susiearch
I'm having the same issue with 2010. (rendered at best 150 dpi) Will this upgrade work for the newer version, or is there another?
Tue, Dec 8, 2009 at 9:47:40 AM | Cannot save or export rendering after it has completed
4 Stars: 205 Votes
For 2010: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12828862
Edited on: Tue, Dec 8, 2009 at 9:49:53 AM
Wed, Dec 9, 2009 at 7:20:51 PM | Cannot save or export rendering after it has completed
ZSPTurbo
It's really simple, this is something that happens at my schools shitty computers too: THE RENDERING IS TOO BIG. Just do the rendering in multiple parts and join them in photoshop.
Your welcome.
Good luck with your crit.
Fri, Mar 18, 2011 at 5:30:21 PM | Cannot save or export rendering after it has completed
efreelan12
This seems completely backward to me... so I have to shrink the image, render in 600 dpi so I can adjust it to a bigger size later.  Just to add a wrinkle same problem in Revit 2011 too.  Sigh.  What's worse its in draft mode and I have removed all the other modeling and furniture out side of view just to get this thing to render all the way.  I wanted this done allready.
Sat, Mar 19, 2011 at 1:16:29 PM | Cannot save or export rendering after it has completed
#11
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
when this happen to me.. .i print to a pdf file, with the correct size of the image
Thu, Sep 20, 2012 at 6:25:57 AM | Cannot save or export rendering after it has completed
#12
geoartarch
This is not a complete solution, but if the rendering is completed, you can try saving the revit file before exporting the image. This helped me more often than not.
Thu, Sep 20, 2012 at 7:58:48 AM | Cannot save or export rendering after it has completed
#13
Contrary to geoartarch, I always found that exporting it first was safer.  Saving it to the project first doubles the amount of space required.
Renderings will not save to project or export
Sat, Nov 29, 2008 at 4:41:39 PM
Capture Rendering/Export Image
Wed, Aug 15, 2007 at 10:34:26 AM
exporing detail view, drafting views, + legend views to other revit projects 9.1
Thu, May 3, 2007 at 2:24:48 PM
HELP! I just rendered an Image and it wont export or save!
Fri, Oct 14, 2011 at 9:59:04 AM
Capture rendering failure.
Mon, Apr 19, 2010 at 4:14:48 PM
Page generation time: 0.3405
