Forums >> Revit Building >> Technical Support >> Revit 2009 interior rendering isue
Wed, Sep 3, 2008 at 11:54:51 AM | Revit 2009 interior rendering isue
Kwotect
Hi everyone, I am having some problems with an interior rendering I am working on.  When I go to render the interior scene and select interior sun only, my rendered image appears to have sun only.  When I render the interior scene and select interior artificial only, I get a scene with artificail light only.  Here's my problem, when I select interior sun and artificial, the rendered scene appears to be sun only and no lights are rendered.  Last week I rendered a interior scene of a kitchen using interior sun and artificial setting and the rendered image came out great.  I can not figure out what is wrong or what I might have done to cause this.  I am stumped.  Can anyone identify what I might be doing wrong or what might be causing this to happen?
Wed, Sep 3, 2008 at 12:17:03 PM | Revit 2009 interior rendering isue
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Can you post an image of your settings you're using?
Wed, Sep 3, 2008 at 12:35:51 PM | Revit 2009 interior rendering isue
Kwotect
Do you need to view the settings of the rendering window or do I need to open all of the windows and post them all?
Wed, Sep 3, 2008 at 12:52:16 PM | Revit 2009 interior rendering isue
alabaster2513
3.5 Stars: 25 Votes
something like this
Wed, Sep 3, 2008 at 1:01:36 PM | Revit 2009 interior rendering isue
Kwotect
Attached are the rendering window settings plus other snap shots of settings within the rendering window.
44033_Rendering_window.bmp44033_Artificial_Lights_window.bmp44033_Exposure_Control_window.bmp
Wed, Sep 3, 2008 at 1:05:18 PM | Revit 2009 interior rendering isue
Kwotect
Additional settings
Wed, Sep 3, 2008 at 1:05:46 PM | Revit 2009 interior rendering isue
4 Stars: 205 Votes
I can't see anything, the images are so small....
Wed, Sep 3, 2008 at 1:12:45 PM | Revit 2009 interior rendering isue
alabaster2513
3.5 Stars: 25 Votes
That is hard to see, but I doubt it's a sun setting anyways. When you render does the render dialogue box locate the artificial lights? Are they all checked in the lights dialogue? What happens when you set the sun settings to a night time setting?
Wed, Sep 3, 2008 at 1:22:44 PM | Revit 2009 interior rendering isue
Kwotect
Attached are larger images of the setting windows.
44039_Rendering_window.bmp44039_Artificial_Lights_window.bmp44039_Exposure_Control_window.bmp
Wed, Sep 3, 2008 at 1:28:50 PM | Revit 2009 interior rendering isue
Kwotect
When I render the scene with interior artifical only the dialogue box locates 75 artificial lights.
When I render the scene with interior sun only...no lights.
When I render the scene with interior sun and artficial the dialogue box locates 36 artificial lights and 605 portals.
Yes the lights are all checked.
I have not tried rendering the scene at night.
Wed, Sep 3, 2008 at 1:39:56 PM | Revit 2009 interior rendering isue
#11
Kwotect
Is there a special setting for night time renderings?  I have always just rendered an exterior scene at night, but I used exterior artificial only to show lights at night along a street.  Would that be the same a night, using interior artificial only?
Wed, Sep 3, 2008 at 1:46:53 PM | Revit 2009 interior rendering isue
#12
alabaster2513
3.5 Stars: 25 Votes
Interesting, I figured it should pick up all 75 lights not 36. If you render sun and artificial and change your settings for the sun to be after dusk it should render better... i think. I use Max myself so i have not tried night scenes in Revit.
It seems your settings are good. Post some draft renders and maybe someone can identify the problem.
Wed, Sep 3, 2008 at 1:52:28 PM | Revit 2009 interior rendering isue
#13
Kwotect
That is what I thought.  I didn't understand why my lights went from 75 to 36.
Wed, Sep 3, 2008 at 1:59:12 PM | Revit 2009 interior rendering isue
#14
4 Stars: 205 Votes
Hi did you upgrade to the WEB UPDATE 20080602_1900 (SP) for Revit 2009????
Wed, Sep 3, 2008 at 2:03:00 PM | Revit 2009 interior rendering isue
#15
Kwotect
Thanks Matt for all of your time trying to solve my problem.
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:39 AM
22
INTERIOR RENDERING
Mon, Jul 9, 2007 at 1:02:31 PM
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
Lights not working when Rendering Sun and Articficial? Revit 2009
Wed, Mar 17, 2010 at 4:38:51 AM
Interior Rendering
Tue, Aug 9, 2011 at 10:33:14 AM
Page generation time: 1.6986
