Forums >> Revit Building >> Technical Support >> separating walls
Sat, Apr 23, 2005 at 5:10:12 PM | separating walls
yoiyoi
i have a storey building with a brick veneer wall on the first floor and vinyl siding wall on the second. in a section view when i try to move one the other moves with it. what can i do to stop that from happening? thanks
Sun, Apr 24, 2005 at 3:53:07 AM | RE: separating walls
Xane
May be, they are join
Tue, Apr 26, 2005 at 7:04:00 PM | RE: separating walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The align tool will in most cases allow one to move without the other. Or detach it from the wall you don't want to move then move then reattach...
Separating walls
Mon, Jul 3, 2006 at 8:18:21 AM
Joining Cavity wall with separating wall
Mon, Jul 14, 2014 at 9:12:31 PM
DWG export, separating materials..?
Thu, Apr 18, 2013 at 5:02:35 PM
Separating wall/ external wall junction
Wed, Nov 9, 2005 at 9:44:26 AM
Finish Flooring as part of Structural Floor assembly
Fri, Dec 26, 2008 at 8:42:14 PM
Page generation time: 0.2648
