Forums >> Revit Structure >> Technical Support >> Toposurface
Tue, Sep 2, 2008 at 8:09:43 PM | Toposurface
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
When working on toposurfaces, typical road ways have v shapes to contours, peaks at the centerline of the road and valleys at the curb edge. The contour line will jump across the v's so you get a false contour. If I set the simplicity factor at 1/2" it does not seem to change. Is there a trick to get the contour lines to stop jumping across?
Wed, Sep 3, 2008 at 4:58:25 AM | Toposurface
4 Stars: 205 Votes
Hi, i think your question a little confusing, are you change the elevation point in your topo surface? Are you creating sub-regions to make the "Road way"? Can you post some screen shots or video to show what are the problem?
Wed, Sep 3, 2008 at 11:59:23 AM | Toposurface
dano3d
3.5 Stars: 3 Votes
What I do in this situation is to insert another point in between that's slightly higher or lower in elevation to FORCE the contour to make the v-shape rather than jumping straight across the roadway.
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:06 AM
Toposurface in Elevations
Thu, Aug 27, 2009 at 1:51:06 AM
what is the easy to do toposurface
Mon, Feb 27, 2006 at 8:44:07 AM
14
Toposurface
Tue, May 11, 2010 at 9:04:45 AM
Page generation time: 1.6111
