Forums >> Revit Building >> Technical Support >> Window family that cuts walls?
Tue, Sep 2, 2008 at 11:40:49 AM | Window family that cuts walls?
JPT23
Is there any way to create a window family with a void or opening that cuts walls when placed in a project? Ex: You have two walls one in front of the other, and when you place the window in one of the walls it creates an opening in the other wall directly across from the window?
Tue, Sep 2, 2008 at 12:41:38 PM | Window family that cuts walls?
coreed
coreed Avatar
4 Stars: 16 Votes
you have to use join geometry and join the two walls and the window will cut both walls.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wall Sweep Overlaps window frames and cuts (some not all)
Mon, Jun 22, 2015 at 8:09:40 AM
Revit 2009 - window family cuts thru some walls but not others?
Tue, Oct 13, 2009 at 2:08:34 PM
Wall Sweep only cuts out window not trim
Mon, Aug 18, 2014 at 10:34:16 PM
Void extrusion family visibility
Fri, Apr 22, 2022 at 7:57:52 AM
Windows in leaning walls
Thu, Aug 11, 2011 at 9:49:46 PM
Page generation time: 0.8943
