Forums >> Revit Structure >> Technical Support >> Families won't load?
Tue, Sep 2, 2008 at 11:16:54 AM | Families won't load?
JHerget
I'm trying to load an HSS column into my project, but every time I go into the HSS family and select the size i want, it doesn't load. Any help is appreciated
Tue, Sep 2, 2008 at 11:21:39 AM | Families won't load?
JHerget
None of the families I try to load will show up, it just defaults to a wide-flange column no matter what type of column I try to load.
Tue, Sep 2, 2008 at 11:35:39 AM | Families won't load?
JHerget
Turns out it is loaded into the project, it just won't let me use it as a structural column, for some reason...
Tue, Sep 2, 2008 at 11:43:37 AM | Families won't load?
JHerget
Nevermind, figured it out...
Tue, Sep 2, 2008 at 12:45:07 PM | Families won't load?
coreed
coreed Avatar
4 Stars: 16 Votes
someone else may also benefit from your solution to the problem.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Sep 2, 2008 at 1:17:06 PM | Families won't load?
JHerget
Fair enough. I was selecting the HSS from the structural framing folder, rather than the structural columns. But the problem I'm having is related to the RISA/Revit link software. Some of the structural members aren't being imported, but when I preload the members it seems to work. I'm still trying to figure it out. But that's a whole different thread...
2011 revit arch won't load families out of the imperial library
Mon, May 9, 2011 at 9:22:28 AM
Corrupt Dwg? - Can't load families [ 1 2 ]
Thu, Jul 16, 2015 at 10:55:31 AM
17
Family Won't Load
Mon, Apr 11, 2011 at 6:34:13 PM
cannot load families into my project
Tue, Aug 15, 2006 at 2:20:21 PM
'Door' Won't Load into Project
Tue, Sep 28, 2010 at 7:11:37 PM
Page generation time: 0.5153
