Forums >> Revit Building >> Technical Support >> Revision cloud
Tue, Sep 2, 2008 at 7:55:07 AM | Revision cloud
Rams
3 Stars: 3 Votes
Hi
Is it possible to draw revision cloud using the same concept in autocad?
In autocad if i draw a rectangle then i can convert it into revision cloud using object option.
Thnx in advance
Rams
Now on the implementation stage....
Tue, Sep 2, 2008 at 9:25:55 AM | Revision cloud
4 Stars: 205 Votes
Hi RAMS, i don't think so, because you can draw some lines (thin, medium, hidden lines....) but you don't have a way to convert those lines in to a "Revison Cloud"...
Tue, Sep 2, 2008 at 9:33:01 AM | Revision cloud
Rams
3 Stars: 3 Votes
I wish it will come in new version of revit
Thnx
Tue, Sep 2, 2008 at 9:35:26 AM | Revision cloud
4 Stars: 205 Votes
There are MANY things i wish it will come in new version of revit....
Revision cloud closes revit
Fri, Sep 28, 2012 at 10:47:52 AM
Hiding a Revision in the Revision Schedule
Thu, Nov 21, 2013 at 3:04:51 PM
Revision Cloud graphics
Mon, Aug 24, 2020 at 7:00:24 AM
Revision cloud parameters
Mon, Feb 25, 2008 at 7:53:53 PM
Revision Cloud
Wed, Mar 7, 2012 at 9:25:48 AM
Page generation time: 1.5725
