Forums >> Revit Structure >> Technical Support >> title bar
Mon, Sep 1, 2008 at 9:51:26 AM | title bar
Warchitect
4 Stars: 5 Votes
The title bar (ie. the circle with the line, that has the title of the individual view, and the scale )
revit 2009.
I want to edit the length of the line of the title bar element, the tutorial says I can select it and then use the blue grip to lenthen it...but when i select the title bar, it only turns red, no grips to grab onto. is there a show grips command?
MIchael
Mon, Sep 1, 2008 at 9:58:29 AM | title bar
4 Stars: 205 Votes
When you pick in the Title bar appears in red color but also you have a blue circle in the end of the line (left and right), where you can pick an drag...
Mon, Sep 1, 2008 at 11:05:36 AM | title bar
coreed
coreed Avatar
4 Stars: 16 Votes
you must select the view itself, not the title.
have a look
http://screencast.com/t/iuPaehuA
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Sep 1, 2008 at 1:01:59 PM | title bar
Warchitect
4 Stars: 5 Votes
GOt it thanks a lot!
How to modify/ customise title bar on sheet?
Fri, Aug 19, 2011 at 6:56:53 AM
JUMPING UI BAR
Mon, Nov 22, 2010 at 1:12:33 PM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Bar top...
Mon, Feb 8, 2010 at 9:19:40 AM
Title Block - How do I insert a drawing title?
Fri, Apr 20, 2012 at 12:18:43 PM
Page generation time: 0.1724
