Forums >> Revit Structure >> Technical Support >> installation error
Sat, Aug 30, 2008 at 6:46:07 AM | installation error
IgnacioPedro
I am getting error code 1601 when trying to install autocad2009revits110sp1, can anyone help
Sat, Aug 30, 2008 at 6:48:35 AM | installation error
4 Stars: 205 Votes
Do you try to install from CD or you download the file from Autodesk Web Site??? (if Download what's the adress)
Sat, Aug 30, 2008 at 8:44:18 AM | installation error
IgnacioPedro
Downloaded from the recommended Autodesk site, I cannot find the address but the filename is
"autocad2009revits110sp1"
Sat, Aug 30, 2008 at 8:57:24 AM | installation error
4 Stars: 205 Votes
Well, from Autodesk this is the site: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11017599
but i don't see that name, if youick in :"Web Update Enhancement List" you will see "Web Update 1 build (20080602_1900)" it's the Only SP to RAC 2009, there is other to Revit SUITE....
Sat, Aug 30, 2008 at 9:35:55 AM | installation error
coreed
coreed Avatar
4 Stars: 16 Votes
if your are in the United States, then that is not the correct installation file for Revit.
try this site
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=9262388
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
REVIT MEP 2012: Installation problem-Error 2343.Specified path is empty.
Fri, Apr 29, 2011 at 7:30:51 PM
Cabinet Files Installation Error while installing RAC 2008
Sat, Mar 22, 2008 at 1:49:13 AM
maxwell installation error!!!!! sos
Wed, Aug 20, 2014 at 3:56:23 PM
13
Installation Problems
Workflow & Implementation >> Chameleon
Mon, Jan 14, 2013 at 12:07:30 PM
Revit 2013 installation problem
Thu, Feb 28, 2013 at 9:23:03 AM
Page generation time: 1.3189
