Forums >> Revit Structure >> Technical Support >> Visibility Graphics - locks up
Fri, Aug 29, 2008 at 9:38:03 AM | Visibility Graphics - locks up
gmosebach
When entering the visibility graphics override menu  my computer seems to completely freeze up for 15 seconds or more.  The mouse freezes on the screen, if i have music streaming it turns off. everything stops
It has always come back, so aside from being annoying and always wondering if the next time might be the one that it doesn't recover from, it's really not a problem.
Is it a known issue that will be adressed in the next build ?
It only started when I began using Revit Structure 2009 - 20080602_1900 (no problem in previous 2009 build).
 Thanks
Fri, Aug 29, 2008 at 9:59:27 AM | Visibility Graphics - locks up
4 Stars: 205 Votes
Well, it's the first time i heard this issue but, Revit Struct. 2009 with Web Update DONE, you don't tell the caracteristics of your machine (RAM, graphics, processor, OS-(32, 64bits)...) and how many programs do you have OPEN at the same time, did you check VIRUS?
Fri, Aug 29, 2008 at 10:32:43 AM | Visibility Graphics - locks up
gmosebach
Running an Intel Core 2 T7600@2.33GHz,  4GB ram,  32 bit,  XP Pro SP3, Nvidia Quadro FX 2500M
I can have nothing but Revit running and it locks up.  Virus scan came back with nothing.  I also opened VG while running a virus scan (to see if it locks up as well) and it also stopped until revit recovered (the list of files symantec displays/scrolls as it scans stopped,  the runtimer than counts in seconds stopped,  however when it started back up it didn't continue where it left off.  i.e.  if it stopped 30 seconds in it didn't pick back up at 31 it jumped right to 45 seconds or so when it continued scanning)
thanks again
Fri, Aug 29, 2008 at 10:58:46 AM | Visibility Graphics - locks up
gmosebach
I believe i figured out the culprit.
I had the OpenGL Hardware acceleration in the Graphics settings checked.  I unchecked that and the visibility graphics open up with no lag/lock up.
I don't know what that means or if it's something that needs addressed in the next build, but I'm just going to leave it unchecked (which i believe is the default).
Fri, Aug 29, 2008 at 11:03:31 AM | gmosebach
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting gmosebach from 2008-08-29 10:58:46
it probably means that there is some compatability issues between OpenGL Hardware Acceleration and your Graphics card.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Aug 29, 2008 at 11:15:55 AM | Visibility Graphics - locks up
4 Stars: 205 Votes
Yeah, go to settings-options and turn off OPENGL, exit from revit and open revit again, see if still continue the problem...
Fri, Aug 29, 2008 at 11:30:19 AM | Visibility Graphics - locks up
gmosebach
well that seems to be what was causing it.  it seems to be working fine again with the OpenGL turned off
 thanks
visibility graphics problems-please help!
Sat, May 28, 2011 at 4:33:53 PM
Visibility Graphics and printing
Fri, Nov 12, 2010 at 3:14:24 PM
Object Style / Visibility Graphics
Thu, Aug 5, 2010 at 3:21:25 AM
How to apply Visibility/Graphics Options to other drawings.
Tue, Jan 10, 2017 at 12:54:10 PM
Visibility Graphics - Linked Models
Fri, Oct 4, 2013 at 7:31:13 AM
Page generation time: 2.3208
