Forums >> Revit Structure >> Technical Support >> hollow mullions
Fri, Aug 29, 2008 at 2:35:29 AM | hollow mullions
durgeshbrijwasi
can anybody tell me how to make a hollow profile for mullion of curtain walls
Fri, Aug 29, 2008 at 2:38:51 AM | hollow mullions and corner mullions
durgeshbrijwasi
and also how to make mitered corner joint...coz at the corners mullions form a butt joint which in case of a odd shape doesnt work out..
Fri, Aug 29, 2008 at 3:31:30 AM | hollow mullions
4 Stars: 205 Votes
Hi, to create a profile mullion you go FILE>NEW>FAMILY and chhose Metric(Imperial) Profile-Mullion.rft or also you can chose Metric(Imperial) Profile-Hosted.rft and change the "category and family" to "mullion"....., but in this case use the first one...
Fri, Aug 29, 2008 at 4:08:31 AM | hollow mullions
durgeshbrijwasi
i followed the above thing and loaded in the project but it is showing this dialogue The selected mullion profile either contains more than one profile loop or an open profile loop and cannot be used. Valid profiles can only have a single continuous closed profile loop. i want to create a hollow profile
Fri, Aug 29, 2008 at 6:39:28 AM | hollow mullions
durgeshbrijwasi
THIS IS A TYPE OF PROFILE I AM LOOKING FOR ...
Fri, Aug 29, 2008 at 8:16:48 AM | hollow mullions
4 Stars: 205 Votes
You can create a mullion like that (i just did it right now), what you must to do is draw that shape BUT you must create 2(two) aditional lines (no matter where) intersecting the 2 lines (the minimum space beetween is 0.00021)" and trim each other to create ONE "polyline", did you understand?
Edited on: Fri, Aug 29, 2008 at 8:56:52 AM
Edited on: Sat, Aug 30, 2008 at 4:31:35 AM
Sun, Aug 31, 2008 at 11:13:01 PM | hollow mullions
durgeshbrijwasi
thanks a lot
Thu, Sep 4, 2008 at 5:15:27 AM | hollow mullions
durgeshbrijwasi
but is it like u cant make hollow profiles may be handrail, frames, sweep, etc.
Thu, Sep 4, 2008 at 5:18:28 AM | hollow mullions
4 Stars: 205 Votes
Sorry, now, i don't understand your point?
Thu, Sep 4, 2008 at 5:20:53 AM | hollow mullions
durgeshbrijwasi
and wat about the joints of the mullion..cant it be a mitered joint..???
Thu, Sep 4, 2008 at 5:46:00 AM | hollow mullions
#11
4 Stars: 205 Votes
Did you create that in a Profile-Mullion Family? Did you try?
See the Video: http://screencast.com/t/k4FX99k6d
Edited on: Sat, Sep 6, 2008 at 9:28:37 AM
Hollow metal window units
Wed, Jan 26, 2011 at 12:36:16 PM
column hollow?
Wed, Jan 28, 2015 at 2:39:47 PM
Hollow Core Block Wall
Wed, Aug 13, 2008 at 7:53:37 PM
Adding mullions to a window
Wed, Dec 14, 2016 at 10:19:19 AM
MASSES SHOW UP AS HOLLOW OBJECTS IN ELEVATIONS IN HIDDEN LINE MODE
Fri, Aug 11, 2006 at 1:18:15 PM
Page generation time: 0.0552
