Forums >> Revit Building >> Technical Support >> Maskng Region lines visible?
Thu, Aug 28, 2008 at 6:56:15 PM | Maskng Region lines visible?
jeffrb25
Revit Architecture 2009
I have an exterior elevation that I masked a region to cut the bottom unwanted objects out of the drawing and the region has a visible outline.  How can I make the region hidden but still mask unwanted objects as I don't see anywhere how to make lines invisible in the mask?
 Thanks
Jeff
Thu, Aug 28, 2008 at 7:02:38 PM | Maskng Region lines visible?
jeffrb25
Ahhhh, I found my answer on another post.  I have to edit the mask then change line types from pulldown.
Thanks for the previous post by : aandr001
Visibility of Filled Region Boundaries over walls
Wed, May 24, 2017 at 1:54:59 PM
crop region visible
Tue, Apr 1, 2008 at 6:54:42 AM
Room Tag not visible using Plan Region? RAC 2009
Wed, Aug 19, 2009 at 12:26:44 AM
Visible floor lines??
Tue, May 22, 2007 at 6:11:03 PM
join wall with split region with wall without split region
Wed, Dec 21, 2011 at 8:30:01 AM
Page generation time: 0.4498
