Forums >> Revit Building >> Technical Support >> Large Toposurface and File Size
Thu, Aug 28, 2008 at 3:35:32 PM | Large Toposurface and File Size
asanders
A co-worker and I are trying to work through a problem in a project (200Shadey that covers a very large, hilly site.  So we have this gigantic complex toposurface... and not much else... in the file and it is already 50MB.  It doesn't seem to really be running that slow, but we noticed when he tried to place an elevation, a "not visible in this view... view parameters... plan regions... blah blah blah" warning came up.  Then, of course, the symbol disappears.  There was nothing in the visibility settings of either the view or the element that seemed to be causing this.  Funny thing is, when we delete the view, the center circle part of the elevation symbol re-appears!!  If we check the box to create a new elevation view, it disappears again!
 Anyway, to get to the point, is this toposurface simply too big for Revit to handle?  Should we be modelling the surface in SketchUp or something else, and then importing or linking it?
Any ideas as to why a giant toposurface at 1":400' would cause elevation symbols to act up?
Thu, Aug 28, 2008 at 3:52:03 PM | Large Toposurface and File Size
4 Stars: 205 Votes
Hi, are you try to modeling this site (surface) in the "SITE" view or in other View (i.e. level1, 2....)????
Edited on: Thu, Aug 28, 2008 at 3:52:35 PM
Thu, Aug 28, 2008 at 3:53:52 PM | Large Toposurface and File Size
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
You should be able to work with a large topo alright as long as your PC is leaning more towards high end.
As far as the elevations there could be a number of things causing it but I wouldn't know where to start without actually being in the file. maybe try created some more levels and add some elevations there and see if they work?
Thu, Aug 28, 2008 at 4:20:13 PM | Large Toposurface and File Size
asanders
I think he created it in a duplicate level of the 'Main Floor' level...  But he ended up copying everything over to a new file, and it seems to be working fine now.  (knocking on my wooden desk...)
Thanks anyway for trying to help!
Fri, Aug 29, 2008 at 10:15:18 AM | Large Toposurface and File Size
Remember that you can always put your site in a workset and not load it.  I like to have it in a linked file.
REVIT MEP typ File size limit
Tue, Mar 12, 2013 at 2:21:48 PM
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
File size issues: Linking multiple Buildings into a Master Site File
Tue, Mar 8, 2011 at 9:52:00 PM
Managing a large multi-house site
Mon, Jul 19, 2010 at 2:34:30 AM
template too large to open after upgrading to 2009
Sun, Jul 19, 2009 at 1:20:37 PM
Page generation time: 1.5133
