Forums >> Revit Building >> Technical Support >> scaling text and dimension according to the scale of view
Thu, Aug 28, 2008 at 8:07:02 AM | scaling text and dimension according to the scale of view
durgeshbrijwasi
i am facing a problem of text heights and dimension heights ..every time i change the scale of the view port according to the sheet size, i have to again change the text heights..Is there anyway by which i can fix the text height according to the scales..same is the problem with room tags, wall tags and door tags...
Thu, Aug 28, 2008 at 8:58:32 AM | scaling text and dimension according to the scale of view
4 Stars: 205 Votes
Did you try to print some of these views in differents scales and see if the height text is fine?
Because Revit, adjust the height text autom. by the scale you put in the view, no matter if you print the same Sheet in a different scales, the heigh of the text is allways the same....
Thu, Aug 28, 2008 at 9:35:03 AM | scaling text and dimension according to the scale of view
coreed
coreed Avatar
4 Stars: 16 Votes
you should be able to find a lot of info posted in the form on this subject. if none of this posted info helps let us know.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Aug 29, 2008 at 2:14:16 AM | scaling text and dimension according to the scale of view
durgeshbrijwasi
thats wat ,,the text size remains same in all scales....i want it differrent in different scales....(If i give a text height of 2mm in 100 scale its the same in 50 scale also ..i want it to be 4mm in 50 scale...and so on ...)
Fri, Aug 29, 2008 at 4:42:00 AM | durgeshbrijwasi
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting durgeshbrijwasi from 2008-08-29 02:14:16
"thats wat ,,the text size remains same in all scales....i want it differrent in different scales....(If i give a text height of 2mm in 100 scale its the same in 50 scale also ..i want it to be 4mm in 50 scale...and so on ...)"
if the text is placed in a view. what you are asking for is exactly what's going to happen when you change the scale of the view.
Edited on: Fri, Aug 29, 2008 at 10:31:55 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Aug 29, 2008 at 10:25:20 AM | scaling text and dimension according to the scale of view
JRMello
So what coreed is getting at is that if you place your text on the sheet rather than in the view you'll get the result you're after. Model text will behave that way as well (but then you have text floating around in your model which is annoying).
Fri, Aug 29, 2008 at 10:26:28 AM | scaling text and dimension according to the scale of view
JRMello
Sorry, nix the part about the sheet. (the model text is right though)
How do you handle dimensioning not-to-scale stuff in Revit?
Mon, Aug 15, 2011 at 2:30:05 PM
Scaling of text, dimensions, and wall textures question.
Wed, Jan 16, 2008 at 11:41:32 AM
View Title scale text won't show
Tue, Dec 29, 2009 at 2:36:51 PM
Scaling Down
Thu, Apr 29, 2004 at 8:57:07 AM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Page generation time: 1.8288
