Forums >> Revit Building >> Technical Support >> Wall/Roof Attachment Phasing Issue
Wed, Aug 27, 2008 at 2:34:16 PM | Wall/Roof Attachment Phasing Issue
Chicago2
1 Stars: 1 Votes
I have an existing roof (to remain) with existing skylights(to be demolished). Under the portion of roof where the demolished skylights are, I have a new wall. In New Construction, when I attach the new wall to the roof, the wall attaches everywhere except where the demolished skylights were. In this area, the wall continues through the roof even through the skylights have been demolished. When the roof is viewed in New Construction, Revit has automatically filled in the cut-outs from the existing skylights but obviously, the existing skylight information is keeping my wall from attaching  to the roof properly. Is there a trick that solves this phasing issue? I really don't want to go in and edit the profile of the new wall to get a clean connection if I don't have to. Is there a way to specify that the old cut-outs for the skylights are now filled in? Any suggestions are really appreciated. Thanks.
Mon, Sep 1, 2008 at 1:19:29 AM | Wall/Roof Attachment Phasing Issue
psymon
psymon Avatar
3.5 Stars: 6 Votes
Go to plan view, pick the wall to attach, choose attach > top, then use tab to pick the infill. It should attach to this then, as well.
Is there a way to subtract roof geometry from wall - Take a look at attachment
Thu, Feb 9, 2012 at 2:59:43 AM
Dormer wall attachment issue
Fri, Apr 15, 2011 at 1:42:00 PM
Wall Attachment to Roof
Tue, Mar 27, 2012 at 3:17:28 PM
Issue Aligning two roofs that exist on different levels.
Tue, Mar 20, 2007 at 6:06:16 AM
Phasing Issue - Proposed Elements showing solid white
Thu, Sep 3, 2015 at 7:36:04 AM
Page generation time: 0.9089
